Hold it. If your coils happen to be the (green?) 3 Ω coils like mine the last thing you need is a relay. This whole relay hype crossed the Atlantic I'm afraid and I doubt there will be any advantages to speak of.
Well, think I found my issue. Borrowed a compression tester and it's down to 110 psi on each cylinder, and should be 170 psi, correct?
Read through this thread a couple of times... can we recap/confirm a bit of history:1. you were riding it regularly a decent distance
Did you hold the throttle wide open with choke off doing the compression test?Sent from my X6pro using Tapatalk
Throttle needs to be wide open, needs air to go into the cylinders in order to compress!
Try draining the float bowls, unlikely but possible they could have water in them. When I was syncing carbs I'd have a small bottle full of petrol suspended from the bars, the petrol was a known quantity then not something that may have been contaminated in the tank. I used a 2 stroke tank off a small Yamaha as they have spouts on the bottom so easy to get a fuel line on them.
Well, it's running again. I was wracking my brain for anything I'd done differently before it all went wrong and realised I'd topped off the tank with premium instead of my usual regular petrol. In an off chance I got a jerry can of regular, drained the carbs and hooked up an auxiliary tank, and it fired second kick. Started 5 more times after that, so hopefully problem solved. Still doesn't make any sense though. Sent from my SM-N9005 using Tapatalk
Quote from: JustcallmeMrT on June 07, 2016, 06:19:59 AMWell, it's running again. I was wracking my brain for anything I'd done differently before it all went wrong and realised I'd topped off the tank with premium instead of my usual regular petrol. In an off chance I got a jerry can of regular, drained the carbs and hooked up an auxiliary tank, and it fired second kick. Started 5 more times after that, so hopefully problem solved. Still doesn't make any sense though. Sent from my SM-N9005 using TapatalkThat is strange because it should of fired on easy start in that case.
