Author Topic: F2 front sprocket  (Read 1137 times)
Offline yozzer74
F2 front sprocket
« on: September 11, 2016, 07:17:17 PM »
Hi just gone to fit my front sprocket but I've forgot which way it goes .I'm sure I've seen a thread on this before but I can't find it .also what length 8mm bolt hold it on and washer .can't seam to find them .and can't see them on parts finch .thanks in advance yozzer
Offline Yurkie
Re: F2 front sprocket
« Reply #1 on: September 12, 2016, 08:39:08 AM »
I can have a look at my bikes front sprocket tonight.
Offline yozzer74
« Reply #2 on: September 12, 2016, 08:41:30 AM »
Offline Yurkie
« Reply #3 on: September 12, 2016, 08:51:08 PM »
Hi, I had a quick look and my sprocket has the flat side to the outside. But this is on a none runner that I brought last year, so I am assuming the previous only sold it with it on the correct way round.
Offline yozzer74
« Reply #4 on: September 12, 2016, 09:16:33 PM »
Cheers for that that's the way I was thinking
« Reply #5 on: September 12, 2016, 11:29:40 PM »
The boss on the sprocket goes inwards and the flat side outwards. It's essential to get right as the chain on the F2 is larger than the K's and if the sprocket is the wrong way the chain rubs the crankcase badly. The clearance between cases and chain is only about 1mm.
Offline Yurkie
« Reply #6 on: September 13, 2016, 08:38:22 AM »
Thanks for confirming mine's on correctly as well
