SOHC.co.uk Forums > CB500/550
Engine teardown and inspection
cantarauk:
Speaking of translation and presentation could someone please explain this to me so I know what is needed. For the clutch components No 12 is a spacer shown below.
But then how do I know what spacer I require for a 500K1 bike ?
I get the remarks with the greater and lower than the engine serials but how does one know what thickness ?
AshimotoK0:
You need to choose the correct thickness to give the correct clearance, as detailed in the Shop Manual.
Bryanj:
Thicknessess of plates are all the same and in the manual and the different part number is square friction pieces not angular. the shims are not easy to get and you work out total play with no shim and a dti take off the clearance and fit shims to the resulting size, unless you are fitting new parts using the old one works
cantarauk:
Thanks both.
Navigation
[0] Message Index
[*] Previous page
Go to full version
