Author Topic: Winter strip down  (Read 3135 times)
Offline mike the bike
Re: Winter strip down
« Reply #15 on: November 08, 2016, 05:59:46 PM »
I've got a set of carb bodies in the shed,  I'll have a look tomorrow.
Offline Chris400F
« Reply #16 on: November 08, 2016, 06:04:00 PM »
We both learnt something there then Chris. So if we ever loose out 'click' at least we know where to start looking now
Very true Julie. I'll just have to hope my ball never drops ....
« Reply #17 on: November 10, 2016, 05:02:01 PM »
Well x3.
Just removed the carbs, partially split the carbs and... no ball or spring.  I've had those carbs apart a few times over the decades and I've never noticed.   I'll have to see what biro has the most suitable spring.
« Reply #18 on: November 10, 2016, 05:37:42 PM »
;D ;D ;D ;D ;D
« Reply #19 on: November 10, 2016, 05:39:15 PM »
Well x3.
That's weird. Does your choke lever still make a clicking noise? Are you looking in the right place?
« Reply #20 on: November 10, 2016, 05:55:23 PM »
No, it doesn't click.  Now it's apart, I can see where it's supposed to fit.
It's always been like it so Soichiro's little workers may have forgotten it.  It may still be on the floor in the factory for all I know.
« Reply #21 on: November 10, 2016, 06:30:21 PM »
  it seems you have a tiny ball missing
« Reply #22 on: November 10, 2016, 07:05:10 PM »
And the spring.  I hope my spare carbs have got them.
Offline Chris400F
« Reply #23 on: November 10, 2016, 09:35:18 PM »
Came across this thread on the US forum. Someone has already had this problem ....
http://forums.sohc4.net/index.php?topic=85415.0
Beats me why it's not in the Parts List though, surely other bikes might use something the same or similar.
« Reply #24 on: November 10, 2016, 11:09:46 PM »
It seems there's more than one under Soichiro's workbench.
Offline Chris400F
« Reply #25 on: November 11, 2016, 10:17:15 AM »
I have just dismantled a scrap LH switchgear and there are two springs as part of the indicator switch.
Free length is a shade over 9mm, O/D is 3.8mm so one of those might do the job even if it needed shortening slightly.
Can send you one if it helps.
« Reply #26 on: November 11, 2016, 10:57:50 AM »
Thanks for the offer Chris but not required.   I dismantled the ratty spare set and found the parts.  I hope this solves the over-rich running.
Offline Chris400F
« Reply #27 on: November 11, 2016, 11:39:06 AM »
No problem Mike, at least I know what is in the switch now!
If your other set is basically complete and you want to have a play and see if the spring would do the job then just let me know.
« Reply #28 on: November 11, 2016, 10:24:25 PM »
Ok I'll do just that
« Reply #29 on: November 12, 2016, 01:06:20 PM »
I've shown the sizes of the ball and spring, the spring requires a lot of force to compress it, so a biro spring wouldn't do.  A spring from inside a switch (kill switch ?) may fit OK.
I've now got my click back that I didn't realise was missing.  Thanks for the advice O wise ones.
« Last Edit: November 12, 2016, 02:24:21 PM by mike the bike »
