Author Topic: Circlip and piston removal ...master cylinder front brake  (Read 2631 times)
Offline Niko
« on: January 15, 2017, 05:35:33 PM »
Hi....I've dug down to my circlip...or what's left of it.
Any tips for getting it out. It won't budge if I try to prize it...the holes and lugs are buggered,
Offline mike the bike
Re: Circlip and piston removal ...master cylinder front brake
« Reply #1 on: January 15, 2017, 05:43:34 PM »
I once used a small screwdriver,  sharpened it up one side, like a chisel.   It weren't easy though.   If only they were made of stainless we wouldn't have all this bother.
Offline Niko
« Reply #2 on: January 16, 2017, 08:34:31 AM »
Cheers Mike....I will have a poke around
Offline Seabeowner
« Reply #3 on: January 16, 2017, 09:54:57 AM »
I did one last week. But it wasn't absolutely awful. But I found it useful to put a bolt back through the the lever pivot point and then use a small screwdriver to lever the piston to the bottom and keep it there. Gives easier access. If the piston is stuck you can try soaking it from both ends and give it a tap.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline tom400f
« Last Edit: January 16, 2017, 11:05:18 AM by tom400f »
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Offline Niko
« Reply #5 on: January 16, 2017, 10:20:02 PM »
Giving up on this....I've made a right mess of what's left of the c clip.....but it still won't budge
Offline paulbaker1954
« Reply #6 on: January 18, 2017, 11:32:18 PM »
My Pistons were completely bug***** couldnt shift the clips and the gudgeon pins were also solid.
Ended up putting them on the milling machine and milled down enough to get the pins and clips free.
Destroyed the pistons and pins but at least saved the rods as I replaced the piston, pins and clips anyway
Brutal but effective
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Green1
« Reply #7 on: January 19, 2017, 08:45:23 AM »
Paul that's a big master cylinder  ;D
The 750 might pull up if they were that big.
Tom I had snap ring pliers like those and had to file them down to reach the clip.I gave up and just prize them out with a small screwdriver and pick now
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline totty
« Reply #8 on: January 20, 2017, 12:53:02 PM »
A bit defeatist but is it worth shifting?
The last knackered one I got out just revealed a very corroded bore.
Offline hairygit
« Reply #9 on: January 20, 2017, 12:57:56 PM »
Yes, always better to save the conrod, which is why he did it!
« Reply #10 on: January 21, 2017, 12:32:58 AM »
Oops sorry misread the post - piston as a master cylinder piston . Now that would boost stopping power🙈🙈🙈
Offline Ashdowner
« Reply #11 on: January 21, 2017, 09:34:24 PM »
I found it impossible to get the circlip out even with one of the lugs and it's hole hole intact but took it to my local fixer and he managed to get a very thin sharpened piece of metal in to the hole and slowly prize it out. It must be impossible if both the lugs are broken.
« Reply #12 on: January 21, 2017, 11:35:44 PM »
Not impossible.   It's like nailing jelly to the ceiling though.  It took me well over an hour.  The trick is to make the aforementioned sharpened chisel - like screwdrivers dig in to the metal,  prising the circlip out as far as you can, keeping it there while you dig the second one in.  Once the clip is free of the groove,  it's relatively simple.
No, I'm not volunteering to go through that again.
Offline Niko
« Reply #13 on: January 23, 2017, 07:54:26 PM »
Oh go on....see if you can beat your personal best time ...
It's a great challenge
Offline Niko
« Reply #14 on: January 26, 2017, 01:09:39 PM »
Well it's out....just not so sure if it's buggered it in the process..
