SOHC.co.uk Forums > CB500/550
Help Combined reg/rec
Bryanj:
Because the original reg is very crude giving full charge, half charge or no charge and those batteries need a smoother charging curve
Wenman:
Thanks flat four! I'm confused as it implies leaving the green from old reg connected as it is earth! Does that mean leave connected to old reg? Only I thought this new unit enabled me to remove old reg or does it mean leave it hanging not connected and remove old reg?
Appreciate the help!
flatfour:
Wenman, according to the instructions supplied with my unit the old regulator should be left fitted and undisturbed, although no doubt someone with more knowledge than I have could advise you on how to achieve the same result in another way if you want to remove it.
mike the bike:
You don't need the old regulator as the new unit supercedes it. Cable-tie the spare green tidily to the loom as it's not required.
Wenman:
Awesome thanks Mike!
Navigation
[0] Message Index
[*] Previous page
Go to full version
