Simple check I would try.Put new and old shells side by side, edges down, to see if they match for size and shape - are the new ones slightly out of round?, even if they are not perfectly circular they should be ok when clamped in between the casing halves.
Quote from: Clem2112 on April 20, 2017, 07:59:43 AMSimple check I would try.Put new and old shells side by side, edges down, to see if they match for size and shape - are the new ones slightly out of round?, even if they are not perfectly circular they should be ok when clamped in between the casing halves. That's why I suggested putting the crankcase halves together, to see if it all drops into place! Chances are at some point since manufacture they have had had something on top of them that has caused them to open up a fraction, my guess would be something dumped on top of the package they were shipped to you in, bloody postal companies! But, provided they aren't creased (easy to spot!) they should be fine to use. I'm about half an hour from you (A little village 5 miles S.E. of Exeter) but due to health issues driving is out of the question at the moment, but if you're not in a desperate hurry I'm more than willing to hop on a bus or train and come have a look for you.
