Author Topic: Clutch Switch wiring  (Read 1750 times)
Offline stevush
« on: May 04, 2017, 04:36:33 PM »
Can anyone help me with Clutch switch wiring please ? The old knackered switch has two wires Green and Green/Red which I assume connect to the same colour wires in the headlamp. The new aftermarket  switch has Black and Green/Yellow, can anyone tell me what goes to what in the headlamp please?
regards
Steve
Offline mike the bike
Re: Clutch Switch wiring
« Reply #1 on: May 04, 2017, 04:55:43 PM »
It doesn't matter, it's only a switch.  Just connect it to the G and G/R in the headlamp shell.
Offline stevush
« Reply #2 on: May 04, 2017, 05:10:54 PM »
Well maybe I have a problem elsewhere. The neutral light works fine, on in neutral, off in gear. When I connect the switch the neutral light is on permanently, whether its in gear or not.
Steve
« Reply #3 on: May 04, 2017, 05:18:37 PM »
Check the diode.  It should only conduct in one direction.   If you havent got a multimeter, a battery and bulb will suffice.
Offline stevush
« Reply #4 on: May 04, 2017, 05:23:10 PM »
Where's the diode ???
Steve
« Reply #5 on: May 04, 2017, 05:27:28 PM »
Its a small rectangular black plastic thing about half an inch big. (Don't correct me on the size, I'm not going to measure it)*
It's under the LH sidepanel and it just pulls out.
* there's some picky sods on this forum.   ;D
« Reply #6 on: May 04, 2017, 05:50:03 PM »
 ;D ;D ;D ;D  ;D Who would that be then Mike ?
Offline stevush
« Reply #7 on: May 04, 2017, 05:56:15 PM »
Found it.. I have a couple of spares too. When the meter is switched to Diode test mode its also continuity ?
It beeps for continuity in both directions on all the diodes I have ?
I'm confused  :)
Steve
« Reply #8 on: May 04, 2017, 06:09:48 PM »
I never use the diode test function; I use the low ohm setting.  I think a battery and bulb gives a more reliable test.
Offline stevush
« Reply #9 on: May 04, 2017, 06:26:35 PM »
Testing with a bulb and a battery, the bulb lights both ways, all the diodes I have read the same. Does that mean they're all duff ?
Steve
« Reply #10 on: May 04, 2017, 06:34:41 PM »
Correct,  they're short.  All the diode does is to allow the starter motor when in gear provided the clutch is in.  It's ok to leave it out - it's just more inconvenient.
Offline stevush
« Reply #11 on: May 04, 2017, 06:40:17 PM »
OK Mike Thankyou, looking at DS, they're £25 and out of stock so maybe I'll leave it out.
Steve
« Reply #12 on: May 04, 2017, 07:03:07 PM »
I'll have a look in my pile onthe weekend.
Offline stevush
« Reply #13 on: May 04, 2017, 07:04:14 PM »
Great stuff, thanks
Steve
« Reply #14 on: May 04, 2017, 09:16:32 PM »
I've studied the circuit and ran some simulations.  If no diode is available there are two alternatives;
*  Leave the diode out
    This means it will only start when the clutch is pulled in, even when in neutral.
*  Short the diode out.
    It will work as normal except pulling the clutch in makes the neutral light come on
This is the best option
« Last Edit: May 04, 2017, 11:26:20 PM by mike the bike »
