Author Topic: Starter solenoid 550f  (Read 1760 times)
Offline petermigreen
Re: Starter solenoid 550f
« Reply #15 on: July 09, 2017, 10:32:52 PM »
Presuming the fuse blows when you press starter button?
If so you're sending 12v positive straight to negative or in other words a dead short which you obviously know as the fuse is blowing. Really solution is to inspect your wiring connections against the wiring diagram for your model one by one and you should spot the problem. Have you by any chance mistakenly bolted a switched live to the frame instead of an earth? Did you have the starter switch apart and trap a wire on reassembly?
Offline bomber
« Reply #16 on: July 10, 2017, 09:12:44 PM »
Plain genius, have loads of the fuse wire , thought will never need it again!
Thank you Norniron!
Just use 15amp fuse wire to test it.
Saves looking for glass fuses
One step forward, two steps backward...
Honda CB550F 1976
Offline bomber
« Reply #17 on: July 10, 2017, 09:14:28 PM »
Fuse blows when I turn key in ignition,
Point taiken, it has to be something silly as you describe...
Honda CB550F 1976
