Author Topic: Honda ss50 indicators  (Read 1706 times)
Offline Pmd31421
« on: July 06, 2017, 11:13:52 AM »
Hi , I'm only getting 4.5v at my indicators and nothing at my headlight . It's got a brand new battery and the horn works fine . Running out of ideas ?
Pete
Re: Honda ss50 indicators
« Reply #1 on: July 06, 2017, 11:21:27 AM »
What's the battery voltage?
Offline petermigreen
« Reply #2 on: July 06, 2017, 11:54:17 AM »
Check for bad/poor earths
« Last Edit: July 06, 2017, 12:07:11 PM by petermigreen »
« Reply #3 on: July 06, 2017, 12:16:13 PM »
This is the only planet where we call the chassis connection an earth.
« Reply #4 on: July 06, 2017, 01:01:44 PM »
Alright, circuit return path connections if you prefer.
My bike is quite muddy though :o
Offline Pmd31421
« Reply #5 on: July 06, 2017, 09:32:36 PM »
Battery output is 6.5 volts.
I've just had the frame plastic coated
« Reply #6 on: July 06, 2017, 09:57:11 PM »
Just for the sake of fault finding, connect a jump lead from the battery negative to the earth on the indicator bulb and see what effect that has.  Actually,  do the same on both bulbs - front and back.
« Reply #7 on: July 06, 2017, 10:56:16 PM »
Definitely need to clean up all earthing points. I use a dremel or similar to clean away the powder coat.
Mikes wise suggestion will bypass any earthing issues and prove definitely if thats the problem.
good luck.
« Reply #8 on: July 07, 2017, 07:52:38 AM »
Don't remember voltages but seem to remember the buggers wouldn't flash unless the engine was running
« Reply #9 on: July 07, 2017, 07:57:19 AM »
Agree with Bryan on that one .. Long term...  possibly use LED replacements if they are available for 6V systems
Offline Woodside
« Reply #10 on: July 07, 2017, 09:01:14 AM »
I have a c100 and the indicators do not flash unless the engine is running and generally needs a rev to get em going
Offline Pmd31421
« Reply #11 on: July 08, 2017, 08:48:59 AM »
Hi , going to check all the earths . Indicators light up but just stay on they don't flash , even with motor running . Headlight .....nothing front or back , although brake light works . Check bulbs they all ok ..
« Reply #12 on: July 08, 2017, 09:49:12 AM »
Same thing with the headlamp;  using the jump lead, supply a negative return to the headlamp bulb and see if it works
« Reply #13 on: July 08, 2017, 10:12:50 AM »
Lights only work with engine running
« Reply #14 on: July 08, 2017, 10:23:46 AM »
And barely better than a candle until 1/2 throttle or more!
