Author Topic: Field Coil/Charging problem...  (Read 5909 times)
Offline lukeralsteen
Re: Field Coil/Charging problem...
« Reply #15 on: August 24, 2024, 12:02:00 AM »
Hey James
I am having this exact same issue with my 77 750F.
How did you solve it in the end? I am going crazy trying to find and fix the problem and any help would be appreciated.
I am replacing the main harness today to see if that helps or not.
Please let me know.
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #16 on: September 21, 2024, 05:05:10 AM »
The white wire conveys the voltage status of the battery to the field coil. Under normal circumstances it goes through the regulator to do this. I think you need to bypass the regulator and see if the battery gets charge; if it does the regulator is faulty.
I think, with your combined RR you have to leave it connected and then run a jumper from the white terminal to the battery +ve terminal.
Run the engine to 2000rpm max. If the battery is charging, the regulator is faulty.
The other thing you could do is buy a copy of the book that BigAl copied the simplified wiring diagram from. You can find it here:
https://www.lulu.com/search?adult_audience_rating=00&page=1&pageSize=10&q=my+cb750+book
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI) & Belfasts, N America!
