Author Topic: New CB750K6 camchain  (Read 976 times)
Re: New CB750K6 camchain
« Reply #15 on: June 02, 2018, 02:43:41 PM »
non upgraded chain should be a little lose, did you have a problem getting the sprocket back on the cam with the chain on ?
Your rocker cover gasket is upside down by the way, will leak if you don't turn it over  ;)
Offline MikeSB6
« Reply #16 on: June 02, 2018, 02:57:26 PM »
Hello, thanks for the tip (?) about the gasket, yes getting the sprocket on the cam was a push,
  Oddly enough, I turned the engine over again a couple of times to check, and the chain has loosened off to where it should be! Could the chain have seated onto the tensioner roller or something?
      Cheers, MikeJ
« Last Edit: June 02, 2018, 03:21:01 PM by MikeSB6 »
« Reply #17 on: June 02, 2018, 03:25:28 PM »
The sprocket should go on with ease. As I said, a mismatch of head and barrels can give you problems .
Offline MikeSB6
« Reply #18 on: June 04, 2018, 05:47:59 PM »
Well, thanks very much for the info., I'll investigate......
       Cheers, MikeJ
