SOHC.co.uk Forums > CB500/550
Air filter case washer 17318-323-010
deltarider:
I have my airfilter case apart and forgot how that part (17318-323-000) should be oriented. You have to look well, but the pic in the CB500K2 (ED, F, G) parts list seems to suggest it protrudes into the chamber and not into the hole. https://images.cmsnl.com/img/partslists/honda-cb500k2-general-export-f-16-air-cleaner_big3IMG01171138_b55e.gif Is that right?
sye:
--- Quote from: deltarider on May 08, 2019, 12:51:43 PM ---I have my airfilter case apart and forgot how that part (17318-323-000) should be oriented. You have to look well, but the pic in the CB500K2 (ED, F, G) parts list seems to suggest it protrudes into the chamber and not into the hole. https://images.cmsnl.com/img/partslists/honda-cb500k2-general-export-f-16-air-cleaner_big3IMG01171138_b55e.gif Is that right?
--- End quote ---
Yep, into the chamber is correct and the filter is slanted at the front to accommodate it.
deltarider:
Thanks Sye.
deltarider:
--- Quote from: sye on May 08, 2019, 02:29:49 PM ---... and the filter is slanted at the front to accommodate it.
--- End quote ---
I am not sure I understand what you mean by that... (forgive me I'm not a native speaker)
sye:
There is an angled slope on the bottom front edge that gives a little more clearance for the threaded part to protrude into the air filter case. I've attached a picture that may help you visualise it.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
