Author Topic: Derby Biker  (Read 1287 times)
Re: Derby Biker
« Reply #15 on: August 19, 2018, 01:58:05 PM »
You have tons more experience on this than me James so I will bow to your knowledge. But that said, the two I have had and the two a mate has had were all under 8k and well worn out internally? Clearly all four had done a great many miles more than indicated.
« Last Edit: August 19, 2018, 02:06:09 PM by royhall »
Offline petermigreen
Re: Derby Biker
« Reply #16 on: August 19, 2018, 02:00:12 PM »
Roy, I agree. I have a suspicion that speedo's are swapped out. This is borne out by the fact you do see these bikes with mismatched clocks.
Peter
Re: Derby Biker
« Reply #17 on: August 19, 2018, 02:28:28 PM »
Do they have a system / process in the USA similar to our MOT's, where something like mileage is recorded each year?. And before anyone pipes up, yes, I know our system of recording is open to abuse with mileage etc.
Offline Moorey
Re: Derby Biker
« Reply #18 on: August 19, 2018, 03:03:45 PM »
I think lot depends on who you buy your import from, by what I've seen some are a little more unscrupulous than others to say the least.
Derby Biker
« Reply #19 on: August 19, 2018, 03:26:46 PM »
Interesting points
« Last Edit: May 28, 2020, 10:30:13 AM by JamesH »
Re: Derby Biker
« Reply #20 on: August 19, 2018, 03:53:21 PM »
Re: Derby Biker
« Reply #21 on: August 19, 2018, 04:05:04 PM »
Hope Graham isn't reading this Julie. Incoming!!!!!
Re: Derby Biker
« Reply #22 on: August 19, 2018, 04:15:32 PM »
He is hiding in a darkened corner James, trying not to spill tears of despair on the other Sandcast engine we have of yours. (oh, and the rest !!! 😰😰😰)
Offline Skunky
Re: Derby Biker
« Reply #23 on: August 19, 2018, 11:40:14 PM »
Thank you all for your welcome. I had a better look at the bike today and there’s some weird things about it.  I took a bit of a punt on the motor, It could be good or it could be shite only a compression test and a first stat will tell.
I’m going to start a Thread on the build and make a better report there. I don’t expect this to be a quick build.
Honda CB400F USA
Triumph Thruxton 900
BMW K100 Custom Buils
