Author Topic: Anyone with SOHC S90  (Read 1282 times)
Offline shifter
« on: September 24, 2018, 05:51:08 PM »
Can anyone advise me where the neutral gear switch is located as having no life in the warning light in the speedo as i would like this to illuminate ,if there is no easy fix will have to wait engine out in winter months ,just wondered if any S90 owner have had this problem,
" RIDDEN NOT HIDDEN"
Cbr500r
550 f1
S90
Offline hairygit
Re: Anyone with SOHC S90
« Reply #1 on: September 24, 2018, 06:54:11 PM »
Yep! It's behind the cover over the front sprocket. It is held by a little clamp held in place by a single bolt. If you remove the wire from the switch and touch it to the crankcase with the ignition on, the neutral light should come on. If it doesn't, check/ change the bulb first, if it still isn't working, check the wiring from the switch (light green/red tracer to the centre pin in the bulb holder, if there's no continuity, there is a break in the loom somewhere, so run a replacement wire up and secure/tape it to the loom.to test the switch in situ, get a spare bulbholder and bulb (6volt) and connect one side to the battery positive (+) and the other to the terminal on the switch. if the bulb lights when it is in neutral and goes out when you select a gear, the switch is okay. 9 times out of 10 it is the buld or wiring that is the issue. Love to see a picture of your bike!
Offline shifter
« Reply #2 on: September 25, 2018, 09:05:09 AM »
Top man Hairy, Thankyou for the clear info as couldn’t find it in clymer or Haynes , yes have continuity to the speedo plus new 6v bulb, so hopefully will take cover off and solve . Many thanks again ...
Cbr500r
550 f1
S90
Offline shifter
« Reply #3 on: September 25, 2018, 09:29:12 AM »
Will try try and dig out a pic of the S90, hey I only live just up the road from you  in next county Som... we come down to to little silver (MX ) sometimes ...
Cbr500r
550 f1
S90
Offline shifter
« Reply #4 on: September 25, 2018, 12:45:03 PM »
Hi hairy , trying to post S90 pic .. [ Guests cannot view attachments ]
Cbr500r
550 f1
S90
Offline shifter
« Reply #5 on: September 25, 2018, 12:50:27 PM »
No luck in finding switch, [ Guests cannot view attachments ]
Cbr500r
550 f1
S90
« Reply #6 on: September 25, 2018, 02:36:35 PM »
Nice little bike you have there ...another York Reg .... probably from Alan Mountains.He sold so many Hondas to Rowntree & British Rail workers that he went on several Honda factory visits/holidays in Japan that were won because of exceptional sales.
Offline hairygit
« Reply #7 on: September 25, 2018, 03:10:58 PM »
Ahh, yours has the 2 part cover, it' will be behind the cover to the left, later models had a one piece cover on that side of the engine, cheaper to manufacture, I think it was late 67-early 68 they changed it. Yours is a very early one, first year of ohc rather than the pushrod motor of the C200 that preceded it. The later one piece cover was shared with the early C90 step through. Anyway, see attached pic, it is in the little triangular bit at the top right corner behind the forward casing. You will need to drain the oil, or lay the bike on it's right side (Easiest!) [ Guests cannot view attachments ]
« Last Edit: September 25, 2018, 03:12:54 PM by hairygit »
Offline shifter
« Reply #8 on: September 25, 2018, 05:05:25 PM »
many thanks Hairy,that explains it clearly,
Cbr500r
550 f1
S90
Offline shifter
« Reply #9 on: September 25, 2018, 07:30:23 PM »
Yes Ash, it had three previous owners all in an around York its where i acquired it in 2013 , it had been semi restored in the 90s and then stored in a shed, i rebuilt the wheels new DID rims ss/s spokes, recovered the outer cover on seat,   foam was in really good nick , checked out the motor (someone had thrown a fair bit of wedge at it), carb /tank was in a bit of a state (tank) a week full of coca cola with hand full of chippings, flushed out after week , refilled with  vinegar for another week .. result brilliant., it had previously been sprayed in celli, so i had the tank done in 2pack in case of petrol spillage , really good match (fiat 152).. fitted a new old stock speedo £££ (not Chinese).. And now the neutral ind light works, happy bunny, thanks for the info Hairy..
Cbr500r
550 f1
S90
Offline petermigreen
« Reply #10 on: September 25, 2018, 10:04:19 PM »
Beautiful machine.
Excuse my ignorance but is this what is known as a sports cub?
Thanks, Peter
Offline kent400
« Reply #11 on: September 25, 2018, 10:38:17 PM »
I think in the sales brochure at the time it was described as the Sport 90. Looks far better in red that the black and a great tiddler.
Offline MCTID
« Reply #12 on: September 26, 2018, 05:48:41 PM »
Just replying to Ash's comments about his local Dealer visiting Japan and I recalled a lady who I used to cadge a lift off to work in Manchester about 1968 ish. Her Husband was a Sales Rep for Honda....and he had already won a couple of Trips to the Honda Factory in Japan for achieving his Annual Sales Targets, but he had this time around, as a reward, been given a small Honda Car - an N600 which was a great little car for his Wife to commute from Breck Road, Eccles to Manchester in.
I was mightily impressed with the Petrol Flap....which could only be opened when the Drivers Door was open.....dead clever in my view....but I was only sweet 18 !
Happy daze !
