SOHC.co.uk Forums > CB500/550
Cb550f engine bars
wolfheze:
--- Quote from: deltarider on November 17, 2018, 04:56:17 PM ---One of the best running CB500s I've heard. Compliments!
--- End quote ---
And there was I thinking it was a bit cam chainy. Probably just used to years of watercooling
firet49:
Thanks Wolfheze yes i mean 3 fixing points but mine is a 550f not sure if the engine mounts are the same as yours.
Did you fit your own?? Did you have to use longer bolts.
wolfheze:
Don't think there is anything different about the frames but I'm no expert! Mine came with the bike and were fitted when the bike was being worked on to sort some poor running issues I had at the time. They didn't mention anything about them not fitting very well.
Navigation
[0] Message Index
[*] Previous page
Go to full version
