Author Topic: CL / CB77 or 72 Spares availability common issues  (Read 1584 times)
Offline Rozabikes Tim
« on: February 21, 2019, 01:18:32 PM »
Just dreaming of future projects. I love the look of sloper style engines over vertical on these earlier bikes. My ideas would be a non standard variant, probably based on the CL frame. What are the common issues with engines and what are spares like to get? Appreciate CL was not imported into the UK and CB parts would be more available (where they do cross over). Just thinking fodder.....
Offline Tomb
Re: CL / CB77 or 72 Spares availability common issues
« Reply #1 on: February 21, 2019, 09:32:14 PM »
The only thing I found hard to locate in engine parts was the primary chain, but that was a while ago and I believe they are more readily available now.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Online AshimotoK0
« Reply #2 on: February 22, 2019, 08:05:55 AM »
Primary chain is now available by 'Sprockets Unlimited' in the UK  at £25. Whole kickstart mechanism including engine side cover is a nightmare as so fragile and poorly designed but I think the CL arrangement is much more robust. To be honest I have a CB72 but, to me, the 160/175 and CB250 engines are a lot better designed bottom ends easier to work on and fix. There are five chains in the CB72, Primary, Cam, Oil filter, Starter and main drive chain. On the CB72 there is a weird kickstart shaft drive shaft that runs in needle bearings through the gearbox shaft ... very expensive to replace.
My mate Graham Curtis is a guru on all things C/CB/CL 72/77 and I can put you in touch if you wish. He has lots of 'em including a '61 CB72 which is quite a bit different than the following years and very rare.
« Reply #3 on: February 22, 2019, 09:22:51 AM »
 Thanks Tomb and Ash. Thought you might pop up in with response Ash and as usual very helpful and knowledgeable.
This ia all just a thinker at the moment but may well take you up on contacting your mate at some point. "Is e oop north wi us?"
Tim
Online AshimotoK0
« Reply #4 on: February 22, 2019, 09:43:43 AM »
Tim
He's in Morley, Ilkeston, Derbyshire !
« Reply #5 on: February 22, 2019, 10:19:42 AM »
Proper bloke then!
Online AshimotoK0
« Reply #6 on: February 22, 2019, 11:19:42 AM »
Proper bloke then!
Say's 'chap' though not 'duck'  :D
« Reply #7 on: February 22, 2019, 11:39:23 AM »
Reet youth! ;)
As a Sussex man by birth and a Derbyshire import in the 70's masquerading as a Northerner, Duck always seems a bit weird....
Offline Tomb
« Reply #8 on: February 22, 2019, 11:44:50 AM »
Oop Norf!!!  hahaha You're all southerners to me.
Another difficult part to find for me was the cam chain tensioner, I ended up making one of my own using the old parts and home made roller following instructions from a lad that races them, forget his name now. Again this was a while ago so may be available now.
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
« Reply #9 on: February 22, 2019, 12:18:02 PM »
Cumbria, dont you have icebergs and stuff there? Properly put in my place ;D
Loving the technical knowledge available on our brill forum as usual.
Online AshimotoK0
« Reply #10 on: February 22, 2019, 12:26:50 PM »
Graham Curtis told me to get a sprocket/roller from a Kawasaki Z650 to make a new camchain tensioner  (I got one from DK it's a brilliant design with bonded in rubber cushioning ...needs a different size needle roller bearing though). Grahams '61 build is here :) Truly amazing detail.
http://www.honda305.com/forum/index.htm    look for 1961 restoration project and he is 'G-man' on there.
« Last Edit: February 22, 2019, 12:52:26 PM by AshimotoK0 »
« Reply #11 on: February 22, 2019, 02:42:59 PM »
Interesting read Ash, what a wreck to start from though! I need to read the full story on a laptop, a smart phone is difficult to read!
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Tomb
« Reply #12 on: February 22, 2019, 03:09:32 PM »
Icebergs!! hahaha not quite. I was out and about around Coniston last Saturday and Sunday on my CB77, it was mild, dry roads and sunshine.
Now you mention it I think I diverted away from home made steel roller the racing boys use as I had an old CD175 roller available and used that in the CB72/77 arm. I'm guessing they are still unavailable?? It was years ago I built my bike up.
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
Online AshimotoK0
« Reply #13 on: February 22, 2019, 04:13:15 PM »
Really rare bike though ..it looks the same as the later model but lots of differences.. he has other projects like that from the early 60's plus he is hoping to build a 600/6 out of two 400/4 engines .
« Reply #14 on: February 23, 2019, 01:52:04 PM »
Jesus Ash. Talk about War and Peace post -160+ pages! Started reading but how do you then go back to where you were as you seem only able to advance a few pages at a time if you are lucky. Is there an easy way?? Good read though and getting very technical with DIY crank rebuild etc.
