With P in the middle is 400, late 550 and late 750 as, the hi/low switch was on the left but it was a different switch to what Sye has You also seem to have the D washers missing from the top yoke
Quote from: Trigger on March 02, 2019, 10:09:41 PMWith P in the middle is 400, late 550 and late 750 as, the hi/low switch was on the left but it was a different switch to what Sye has You also seem to have the D washers missing from the top yoke Nope, D washers both in place, in fact I have two spares I think. The handlebars are not original but they are drilled. From a 550 I think, so unless I re-drill them, the separate switch has to go on the right. The switches are a bloody nightmare TBH, there are so many options for different models and different countries. It also doesn't help that they are discontinued and when they do come up, someone wants the cost of a cottage in Wales for it.Will stick with what I have until something comes up.
Looking at that diagram connect your br/blue to the br/white in the headlamp shell and its the same.( i knew i remembered white from somewhere!)
