Author Topic: NEED TO TALK ABOUT TANGS 😀😀  (Read 1465 times)
Offline Moorey
Re: NEED TO TALK ABOUT TANGS 😀😀
« Reply #15 on: April 08, 2019, 09:45:39 PM »
One of mine on the 350 looked like that.
Did you flatten it out a bit Chris?
No I just set the float height to it.
« Reply #16 on: April 08, 2019, 09:47:18 PM »
Yes, that's what i did. Thanks
Offline Moorey
« Reply #17 on: April 08, 2019, 09:51:22 PM »
Or rather I should say I checked the float height and it was ok with it bent like that so I left it as it was.
« Reply #18 on: April 08, 2019, 09:53:02 PM »
Yep, in my case 22mm is 22mm regardless of what shape the tang is in 😀😀😀
Offline Moorey
« Reply #19 on: April 08, 2019, 10:02:12 PM »
I would have thought so the measurement is taken from as soon as the spring loaded end of the needle touches the tang I believe.
Offline Raymond_Y
« Reply #20 on: April 08, 2019, 10:05:43 PM »
From an engineering perspective, a curved tang just does not feel correct, although that is not to say it won’t work.  But if there is a problem, then the curve in the tang, and how it works with the valve could be a contributing factor.  As someone said earlier, the brass parts of the float assembly I believe were stamped and that would produce a flat tang.  However, what is not broken does not need fixed.
Raymond
1971 CB500K0 (being rebuilt)
1977 CB550K3 (bases for future 650 cafe racer)
Q plate CB550 in bits
« Reply #21 on: April 08, 2019, 10:17:36 PM »
This is obviously the main difference between an Engineer and a Nurse. A Nurses favorite saying is     ' Don't try and fix it if it's not broken fully, you will only make it worse' 😀. I'm thinking that as long as the tang is not twisted from one side to the other and the tang is set right to give me 22mm float height.....its doing its job.
Offline Moorey
« Reply #22 on: April 08, 2019, 11:01:53 PM »
I put new carb kits in all four carbs and none of them would seal even when tapping the bowls.  I tuned the petrol tap off added 100ml of 2stroke oil in the tank and started the engine with he tap turned off and run it until he carbs were nearly empty turned the tap back on to fill the carbs keeping a eye on the overflows and run it until hot . Turned it off and it's been fine since. Do you run your carbs empty  when you park it up if your not going to use it for a while Julie.
« Reply #23 on: April 08, 2019, 11:17:39 PM »
Nope, never let carbs empty but then all my bikes get ridden very regularly, ie, every few days.
Offline matthewmosse
« Reply #24 on: April 09, 2019, 08:15:29 AM »
When my cb500 was in daily use I still found turning the fuel off and keeping it running a few minutes every so often plus a dose of redex was a far easier way to get the carbs to stop leaking periodically than taking carbs off.
Offline Raymond_Y
« Reply #25 on: April 09, 2019, 10:11:30 AM »
My wife would agree with your comment on engineers.  One final thought, if you gave not already done so, you could swap the float with the curved tang with one of the others and see if the leak follows it as a process of elimination.
Raymond
Offline paulbaker1954
« Reply #26 on: April 09, 2019, 12:54:52 PM »
Dunno know about Tangs but I have had no end of overflow issues and I have lost count of how many times the carbs have been off and on.
Twice I have bench tested with fuel only to put them back on bike and one of the sodding things would overflow again.
In the end i replaced with ones from Cruzinimage and things have been OK since then
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
