Author Topic: Spacers on rear wheel  (Read 597 times)
Offline Golfcarmad
« on: April 26, 2019, 02:19:06 PM »
When trying to fit the 2 spacers on rear wheel I am having to crow bar with excessive force to fit wheel. My bike is an f2 now fitted with f1 swinging arm.can anyone advise if spacers are different in length on the 2 models?? My spacers are 28mm and 44mm in length. It is possible mine is USA import due to wiring which has been much closer to us wiring diagram in Haynes. Cheers Paul
More bikes than sense!!
Honda 400/4 (almost fully rebuilt)
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Honda CBR500F (Import)
Francis Barnett Plover
Puch Maxi 2 speed (makes me smile)
Cb100n cafe racer
50cc scooter (now does 52 mph)
Re: Spacers on rear wheel
« Reply #1 on: April 26, 2019, 02:25:31 PM »
USA and UK, F1 and F2 swing arms are the same (except fort he foot peg mounts on the F1). The spacers should be very similar in length both sides, it sounds like you have an incorrect spacer.I have a spare set of spacers here, I will measure them in a minute.
« Last Edit: April 26, 2019, 02:27:10 PM by Nurse Julie »
« Reply #2 on: April 26, 2019, 02:35:12 PM »
« Reply #3 on: April 26, 2019, 02:36:05 PM »
Have you got the correct rear wheel?
Offline Golfcarmad
« Reply #4 on: April 26, 2019, 02:47:25 PM »
Only have wheel n spacers that came with bike which was running before strip down! Weird??
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
« Reply #5 on: April 26, 2019, 02:50:30 PM »
It may have been running before strip down but was the back wheel where it was supposed to be?. The spacers you have are huge, almost suggest wrong wheel or wrong hub fitted.
Edit...you say you have a different swing arm now, was the one you took off correct, is this one correct?
« Last Edit: April 26, 2019, 02:53:06 PM by Nurse Julie »
Offline Golfcarmad
« Reply #6 on: April 26, 2019, 02:56:28 PM »
Comstars fitted.1.85 x 18. Must admit rode back round block when delivered.no noticeable problem.bought it to do complete rebuild.thanks for measurements.if cannot sort at Stafford etc will take long one and cut down to your measurement. Thanks
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
« Reply #7 on: April 26, 2019, 03:00:40 PM »
Comstars are not the same size as standard CB400/4 wheels / hubs / plate etc. The measurements I have given you for the spacers  are for a standard 400/4 swing arm and wheel, with standard 400/4 hub, brake plate etc. The wheel may be the same size but nothing else is.
« Last Edit: April 26, 2019, 03:39:53 PM by Nurse Julie »
