Author Topic: No 1 Carb?  (Read 624 times)
Offline peterengland
No 1 Carb?
« on: June 08, 2019, 04:43:52 PM »
Recently cleaned carbs out and bike was running fine and dandy, now it is missing, no1 is not firing, plug out and is sparking just fine so has to be carb issue as when i take leads off all other cylinders it then runs like a pig, as it should, but when I disconnect no 1 it doesn't miss a beat, apart from the beat it misses anyway! so what can it be..any ideas?
550 with PD46A
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Re: No 1 Carb?
« Reply #1 on: June 08, 2019, 05:11:32 PM »
Has the PD carbs got drain screws?
Check fuel is in the float bowl.
Is the fuel low in the tank?
Try it on reserve
Re: No 1 Carb?
« Reply #2 on: June 08, 2019, 06:27:18 PM »
yes have drain screws, tank full and flowing to the other 3 fine
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Re: No 1 Carb?
« Reply #3 on: June 08, 2019, 06:40:50 PM »
Could be a sticky float/needle valve.
Try tapping the carb(s) with plastic hammer.
Leave drain out. And fuel on.hopefully it may shake it loose.
When you get it done.
Give it a good dose of Redex.
Then take it for  long run
Online JamesH
Re: No 1 Carb?
« Reply #4 on: June 08, 2019, 09:48:08 PM »
Should be able to remove bowl #1 with the carbs in-situ. You can then check the flow through the float valve..
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: No 1 Carb?
« Reply #5 on: June 09, 2019, 04:25:10 PM »
I had this on #2, pulled the cap off while running and no change in running.
Swapped 1&2 plugs over and the fault went to 1
So it turned out to be a faulty plug.
Also take drain plug out of 1 and see if the fuel keeps flowing out.
If not could be jammed float valve.
Several times I’ve taken the bowls off in situ.
Fiddly but used a driver bit in a small reghtangled Torx handle.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
