Author Topic: Forks and genernal CB750 K6 rennovation....  (Read 6886 times)
Re: Forks and genernal CB750 K6 rennovation....
« Reply #15 on: January 23, 2009, 08:27:49 PM »
Those torque settings should be ok as 550 and 750 front end are very similar and yes the washer does look like somebody nibbled an edge off
Offline scotia_steve
« Reply #16 on: January 24, 2009, 02:14:24 PM »
Seems to be the same part numbers for the front end.
All back together now, but I decided I don't like the paint on the forks anymore and will polish :)
The fuel is the issue. It seems to separate very quickly. Drained it and it worked a treat!
Also put w connectors in the front headlamp loom to the switch - much better than Halfords bullets!
« Reply #17 on: January 24, 2009, 02:20:03 PM »
I agree, modern petrol, or gas as the yanks call it, does go off a lot quicker than it used to.
When new, first Hondas to need draining if stood were CX500 & CB750/900 twin cam(79+) and it was usualy anything over 8 days drain the carbs, what was in the tank stayed OK though. Never did figure out why just drained them in the workshop on pre- customer checkover
« Reply #18 on: January 24, 2009, 03:03:55 PM »
It was like night and day when I drained - started really quickly!
