Author Topic: 400/4 Front Brake  (Read 669 times)
Offline Deano400
400/4 Front Brake
« on: June 24, 2019, 09:10:52 PM »
Help needed again.
My brother and I have both got 400/4s. When the front brake pad is removed from the piston side, one 400 has a square section nylon? ring sat between the piston and pad, the other 400 doesn't. I can't find any reference to this part. Should it be there or not? Can anyone enlighten me please? TIA.
John
Online Johnwebley
Re: 400/4 Front Brake
« Reply #1 on: June 24, 2019, 09:29:07 PM »
Yes.
Some pad suppliers include it.
Not sure what it does.
Offline hairygit
« Reply #2 on: June 24, 2019, 10:51:02 PM »
Yes.
It's an attempt to reduce brake squeal!
Offline Athame57
    • SeaWitch Artist
« Reply #3 on: June 25, 2019, 04:55:45 AM »
Well...it doesn't seem to help!  :o
I brake for animals!
1978 CB400F2 called Elen.
Offline mike the bike
« Reply #4 on: June 25, 2019, 08:36:02 AM »
I was going to tackle this job lunchtime but the sky is leaking badly so I took the car.  I'm going to wrap PTFE tape round the edge of the pad.  I'll report back when I've done it.
Bloody brake sounds like a pig in agony.  I don't like using it.
Online Johnwebley
« Reply #5 on: June 25, 2019, 09:16:14 AM »
I use copper grease on the rear of the pad and around the edges.
Seems to work. If I get squeal it's at low speed.
Then I use the brake hard to clean the faces. And the disc.
Offline Deano400
« Reply #6 on: June 25, 2019, 10:15:03 AM »
Thanks John & Hairy
« Reply #7 on: June 25, 2019, 11:03:45 AM »
Done all that last week, John but the squeal has returned.
