Author Topic: Horn  (Read 939 times)
Offline Oggers
Horn
« on: April 06, 2020, 07:58:05 PM »
Quick Q. Battery is down a bit - to @11V . Is this enough to get a sound from the horn?
Re: Horn
« Reply #1 on: April 06, 2020, 08:39:19 PM »
A very weak hum yes a parp no
Offline ka-ja
  • ken
  • yoshi 460
Re: Horn
« Reply #2 on: April 07, 2020, 09:38:49 AM »
Or a strangled duck noise.
nice bike,nothing in the bank
Re: Horn
« Reply #3 on: April 07, 2020, 09:42:02 AM »
Or even just a strangled 'click' sort of noise.
Offline Oggers
Re: Horn
« Reply #4 on: April 07, 2020, 10:39:41 AM »
Yes, I'm getting the strangled click! Very faint, but something does happen when I press the button. Continuity in the horn and when the switch is depressed is present, and yes, I have fiddled with the small screw at the back a little to see if that was the fault. Put back to original position. No big deal, just testing things after the wiring nightmare......
Offline bobv7
Re: Horn
« Reply #5 on: April 07, 2020, 11:06:38 AM »
Does your engine stop when you run out of petrol? Same applies to your horn. ::) No leccy, no parpy. :o
Offline ka-ja
  • ken
  • yoshi 460
Re: Horn
« Reply #6 on: April 07, 2020, 04:08:15 PM »
As long as the engine does not stop when the horn button is pressed ;)
Offline bobv7
Re: Horn
« Reply #7 on: April 07, 2020, 05:12:19 PM »
Connect the horn directly to a FULLY charged battery. Does that work? If not give the horn interior a blast with switch cleaner and if it still doesn't work then buy a new horn.
If it does then check the continuity from the battery to the horn button and from the horn button to the horn connection leads.
Re: Horn
« Reply #8 on: April 07, 2020, 09:25:00 PM »
Offline Athame57
    • SeaWitch Artist
Re: Horn
« Reply #9 on: April 07, 2020, 11:08:44 PM »
Actually it's time I got  a new one too. I've got this aftermarket thing that looks like a snail and I could fa*t louder!
I brake for animals!
1978 CB400F2 called Elen.
Re: Horn
« Reply #10 on: April 08, 2020, 06:36:53 AM »
If the big nut on the back has been moved, it needs retuning  ;)
Offline Oggers
Re: Horn
« Reply #11 on: April 08, 2020, 07:52:42 AM »
Trigger - the big nut on the back has definitely moved as I took the horn off its brackett! i did wonder if it has an effect. Do you retune with this nut or the small screw? - or both?
Offline Oggers
Re: Horn
« Reply #12 on: April 08, 2020, 08:46:40 PM »
Appreciate a test would be to connect to a fully charged battery. I have no spare - so would crocodile clips to the car battery suffice? Obviously a car battery carries a greater punch -  just afraid of damaging things
Offline hairygit
Re: Horn
« Reply #13 on: April 08, 2020, 09:05:44 PM »
Car battery won't hurt it, 12voltsis 12volts, bike or car battery. (Provided it's a 12volt bike)
Re: Horn
« Reply #14 on: April 09, 2020, 09:56:43 AM »
If you put the small screw back to factory set. Then start tuning the big adjuster on the back, one you have the connection start on the small screw. Hard to explain this  ;)
