Author Topic: points  (Read 1083 times)
Offline gazadi
points
« on: May 18, 2009, 08:24:02 PM »
Fitting   condensers, points and setting gap and advice instructions???
Re: points
« Reply #1 on: May 19, 2009, 05:13:07 AM »
Gap 0.35mm timing on "F" mark with static bulb, keep checking both as when you rotate the plate the gap alters and when you re-gap the timing alters.
Get both spot on and you will be well rewarded
