Author Topic: Flat tyre (again)  (Read 1034 times)
Offline nairb
Flat tyre (again)
« on: February 25, 2021, 10:22:44 PM »
So at a lowish speed The rear kicked out and I stopped within 50 meters.  Lucky really.  And there it was, a flat rear tyre.  Within an hour I was on the back of a pickup and taken home.  All very civilized.
Heres a pic of the offending nail, or screw .
Its a tyre with a tube.
So in times gone past all I have done is replaced the inner tube with a new one.  But I have wondered if I should also have the tyre itself repaired also.  I have gotten old and the doubts are creeping in. I always thought a new inner tube was all thats needed.
ta
Nairb
« Last Edit: February 25, 2021, 11:24:35 PM by nairb »
cb550k3, cl450k5, re5m, xs650xs2, mt500, kettle, gt550 x2,  gt380 Kz750 twin cb360K0
Re: Flat tyre (again)
« Reply #1 on: February 25, 2021, 10:32:03 PM »
You can use a patch on inside of tyre carcase. Cleaned and rough sanded,  then coat with rubber glue and let dry to tacky. Finally apply a big 3 inch diameter car patch.
« Reply #2 on: February 25, 2021, 10:46:37 PM »
I’ve always just changed the tube, that’s what’s keeping the air in.
« Reply #3 on: February 26, 2021, 03:13:42 AM »
You only repair tyres if tubeless, if casing damaged i would not repair a bike tyre
Offline SumpMagnet
« Reply #4 on: February 26, 2021, 02:00:10 PM »
just replace the tube...job done
CB750F2 - in pieces
« Reply #5 on: February 26, 2021, 04:19:07 PM »
I agree I would just fit a new tube - a vulcanised patch as per tubeless tyres would just make the hole even bigger for no benefit.
Out of general interest I always replace tubeless tyres if I get a puncture - just not worth the risk.
« Reply #6 on: February 26, 2021, 04:36:52 PM »
I used to repair tubes with patches when I was a penniless student, I think going racing cured me of that habit - punctured tubes now go straight in the bin, or get cut up to make big rubber bands.
Offline nairb
« Reply #7 on: February 26, 2021, 11:05:18 PM »
I used to repair tubes with patches when I was a penniless student.
Yup I used to do the same many years ago.  Now old age and a few more pennies has changed all that.
Here is a pic of the old inner tube.  Fair old patch needed to fix it.  All from a small screw and about 50 mph.
Thanks to all.  New inner fitted.
Nairb
Offline SumpMagnet
« Reply #8 on: February 27, 2021, 07:33:49 PM »
I'll have proper repairs done on tubeless tyres...but that requires tyre removal. I use a temporary plug system to get me home, then have a pro do any repairs. There are strict guidelines on what can/can't be repaired, and how many repairs a tyre can endure.
Tubes....I bin and replace.
CB750F2 - in pieces
