Author Topic: Fuel Height  (Read 2298 times)
Offline Steris
Re: Fuel Height
« Reply #15 on: April 23, 2021, 12:42:15 PM »
The vents and over flows are all clear. The advance retard seems ok, with a strobe it sits on the F mark on tick over and starts to advance about 1200-1500 rpm full advance about 3000rpm
Its driving me nuts :)
Offline Charliecharlcomb
Re: Fuel Height
« Reply #16 on: April 23, 2021, 01:12:13 PM »
I know that feeling. At least you are getting lots of practice removing and refitting the carbs. If you manage to fix it, do let us know.  :)
Re: Fuel Height
« Reply #17 on: April 23, 2021, 03:26:47 PM »
Have you tried spraying the intake rubbers from carb to head with something like wd 40 while running to check for air leaks?
Offline murdock
Re: Fuel Height
« Reply #18 on: April 25, 2021, 03:05:23 PM »
Check that the tips of the mixing screws are fine, they must have a conical tip, you turn until reaching the stop without forcing it, and then in a counterclockwise direction unscrew about 2 turns, the 4 equal, with rolling 100 meters You will notice if it drowns or lack of gasoline, if when placing the carburetors they lose their blows, a float may be hooked and not cut the valve, what jets do you have? You say that the needles are at their maximum height, that will only influence after 1 / 2 throttle up to the wot. mark the stroke of the fist in 1/8, 1/4, 1/2 and 3/4 and check how the motorcycle behaves in each position
Offline murdock
Re: Fuel Height
« Reply #19 on: April 25, 2021, 03:17:08 PM »
guidelines
Offline Steris
Re: Fuel Height
« Reply #20 on: May 06, 2021, 08:34:28 AM »
Would low compression cause slow running issues? I'm struggling to think of anything else that's causing my problem. It runs lovely over 3000rpm sits at 60 70 mph great, it also ticks over at 900rpm when cold, but once hot either dies or revs itself up to 3500 rpm. 🤔🤔🤔
Offline murdock
Re: Fuel Height
« Reply #21 on: May 06, 2021, 08:46:07 AM »
Re: Fuel Height
« Reply #22 on: May 06, 2021, 09:15:46 AM »
Have you any compression readings for it?
Runaway idle speed is always excess air however it gets the supply to the combustion chamber.
Offline murdock
Re: Fuel Height
« Reply #23 on: May 06, 2021, 09:39:57 AM »
That the air screw rotates 3 turns and there are no changes in idle is not the right thing to do, I think you have the problem in the slow jets, I think you should reduce, which jets do you have at 38, 40?
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: Fuel Height
« Reply #24 on: May 06, 2021, 10:19:30 AM »
I had the same with a hanging idle and found one or two carbs needed balancing.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline Steris
Re: Fuel Height
« Reply #25 on: May 06, 2021, 10:32:08 PM »
Hi Merdoc
Everything in the carbs are original  so 40 pilot jets. I'm going to  remove the carbs again this weekend and drill out all the brass plugs in the pilot passage ways and make sure they are 100% clear..
Offline deltarider
Re: Fuel Height
« Reply #26 on: May 07, 2021, 11:47:28 AM »
I wouldn't drill out anything. If yours is a CB500, realise that a common mistake is trying to achieve a highest possible idle rpm by turning out the airscrews. No doubt the engine will idle nicely and pur like a kitten, but it comes at a price: driveability is gone and you'll experience a poor acceleration. Once the engine is hot, rpm will not drop. Realise these are quite simple carbs that lack acceleration jets. Therefore airscrews need to be set as is specified in the manual, even when you need to adjust the big idle knob to arrive at an acceptable idle rpm. Mixture will be quite rich and I wouldn't be surprised an exhaust gas meter would show 5% CO. I recommend an idle rpm of about 1100-1150. Also realise that after a cold start, you will need to maintain a raised idle to prevent stalling. Some do it by keeping the throttle grip twisted a bit (as described in the Owner's Manual), others use the big idle adjuster knob, which they will reset at a traffic light, once the engine has warmed up sufficiently.
Verify fuel supply is constant without hesitations. Abstain from 'extra' inline fuel filters; I had nothing but trouble with them. If float valves and needles are somewhat sticky, a fuel additive like Redex may help.
Realise that todays gas is not the same as in the 70s.
« Last Edit: May 07, 2021, 12:08:07 PM by deltarider »
Offline murdock
Re: Fuel Height
« Reply #27 on: May 07, 2021, 11:56:29 AM »
Tell us more, what air filters do you carry?
Have you checked the choke?
Offline murdock
Re: Fuel Height
« Reply #28 on: May 07, 2021, 05:26:42 PM »
http://forums.sohc4.net/index.php/topic,5410.0.html
I hope you find the answer here, don't give up !!!
Offline Steris
Re: Fuel Height
« Reply #29 on: May 07, 2021, 11:50:42 PM »
Thanks for the link Murdoc lots of good info on here, I'm running a standard air filter. I'll read through all this and try again. I'm not going to give up 🤣🤣
