I wonder if cruise control is an option, are these kits universal?
I've fitted a less tight throttle spring on my 550/4 Mongrel because I found it a bit hard work after a few hours riding, it works a treat. I had to retain a bit of tension though as I don't have a return throttle cable fitted to this bike but this snaps back just perfect.
Quote from: Nurse Julie on May 18, 2021, 12:51:24 PMI've fitted a less tight throttle spring on my 550/4 Mongrel because I found it a bit hard work after a few hours riding, it works a treat. I had to retain a bit of tension though as I don't have a return throttle cable fitted to this bike but this snaps back just perfect.Hi JulieMay I ask where did you source your spring from please Would like to use a lighter spring on my CB400F as starting to do longer rides out +100 miles so would like to lighten up the throttle a bit if possibleMany thanks AlSent from my iPhone using Tapatalk
Quote from: allankelly1 on June 01, 2022, 11:53:06 AMQuote from: Nurse Julie on May 18, 2021, 12:51:24 PMI've fitted a less tight throttle spring on my 550/4 Mongrel because I found it a bit hard work after a few hours riding, it works a treat. I had to retain a bit of tension though as I don't have a return throttle cable fitted to this bike but this snaps back just perfect.Hi JulieMay I ask where did you source your spring from please Would like to use a lighter spring on my CB400F as starting to do longer rides out +100 miles so would like to lighten up the throttle a bit if possibleMany thanks AlSent from my iPhone using TapatalkHi AlI sourced it from a spring parts bin in the workshop I've no idea what model Honda Four it came from, all I can remember is that the spring tension was a little less than the one I had fitted and overall it was a few mm longer.
This was discussed at quite some length in one of my posts, it was the considered opinion that using a small split ring (like off a key ring) is a good solution, just slip it onto the end of the spring and the post it supposed to hang off. It has to be a small split ring though, any beach fisherman has a few in his tackle box as they come in handy for beach weights etc
