Author Topic: New Member - CB 550  (Read 5218 times)
Offline totty
Re: New Member - CB 550
« Reply #15 on: February 01, 2010, 01:10:56 PM »
Good news on the dust cap, I'd like to get the bike back on the road ASAP, get some miles on it and treat it as a rolling resto. I already have a new cap on order along with a few service parts.
Thanks for the pilot jet tip. I think I've read elsewhere that these are pressed in but can be pulled out and tapped back in, I think I'll try a bit of redex first.
Thanks for the info and links on manuals, Steve is posting me some on CD.
Allan
Offline totty
« Reply #16 on: February 02, 2010, 11:36:49 AM »
I've now got a pic online:
and also written a to do list to start on Sunday, although I may make an attempt to get it running before then as it's really bugging me.
adjust tappets - Done
strip and clean carbs - Done
static balance carbs - 1/8" drill bit - Done
check rubber inlets  - Done
refit carbs - Done
change plugs - Done
check coils/leads/caps - Done
drain fuel - Done
replace air filter - Done
check points condition and alignment - Done
gap points - Done
lube points cam - Done
static time points - Done
set dwell
dynamic time
check advance
change oil and filter - oil looks new.
change brake fluid - Done
replace or temp glue fork dust cap
clean and oil chain - Done
fit number plate - Done
Grease swing arm pivot- Done
repair seat tear - Done but not happy with it
replace seat lock
MOT - Booked for Sat
Tax
« Last Edit: March 03, 2010, 08:50:43 PM by totty »
« Reply #17 on: February 02, 2010, 11:48:00 AM »
So what are you going to do on Monday?
 ;D
2022 Tiger Sport 660
Offline totty
« Reply #18 on: February 02, 2010, 01:13:58 PM »
Go to work feeling annoyed that I only made it to line 3 on my list on Sunday, and due to being on the IOM the following weekend I won't get to work on it in daylight for another 12 days  :(
Offline totty
« Reply #19 on: February 07, 2010, 04:02:31 PM »
Having done a few jobs it's a totally different animal, sounds much better and is keen to rev. I'm happy with that for a days work, although my back isn't  :(
Offline totty
« Reply #20 on: March 03, 2010, 08:52:43 PM »
It's booked in for an MOT on Sat so wish me luck  :-\
Offline UK Pete
« Reply #21 on: March 03, 2010, 10:08:40 PM »
Good luck with MOT , mine went through the other day it is a good feeling
Pete
