Author Topic: New e-bay listing for SS cam cover bolts on Honda 400/4  (Read 1509 times)
« Last Edit: June 23, 2021, 05:17:09 PM by Macabethiele (Ted) »
Re: New e-bay listing for SS cam cover bolts on Honda 400/4
« Reply #1 on: June 24, 2021, 04:40:19 PM »
No, they are just cheap stainless bolts readily available on eBay. At least go to Middletons website and buy some polished ones.
« Reply #2 on: June 24, 2021, 05:14:09 PM »
We have bought quite a few bits direct from Tina. Not SS ones but she can supply some real odd ball lengths cut to our requirements.
« Reply #3 on: June 24, 2021, 06:13:49 PM »
My crancase set from them were polished. Then again I guess there is polished and dazling !
It appears the bolts are also not fully threaded hopefully  the right length for the job.
Offline hairygit
« Reply #4 on: June 24, 2021, 06:20:38 PM »
Using the correct terminology, a bolt has an unthreaded portion, if it is threaded it's full length it is a setscrew
Sent from my JNY-LX1 using Tapatalk
« Reply #5 on: June 25, 2021, 09:31:21 AM »
I live and learn thanks for the correct terminology oh hairy one that's the opposite to what I thought somehow.
In my head setscrew sounds more precise so ought to have a shoulder or unthreaded section.
Sadly I'm still firmly in the Farhenheit zone even though I used SI units at Uni - I still can't get used to Centigrade for the weather either.
I am clearly either a Ludite or mentally resistant to change there is no hope for me I'm a lost cause. lol
« Reply #6 on: June 25, 2021, 10:13:52 AM »
Me 3 but then we all buy timber as 3mtr of 4x2 inch!!
« Reply #7 on: June 25, 2021, 10:16:27 AM »
I bought a piece of 3/4 ply yesterday and had it cut to 24' * 608mm. No hope for me either, the woodshed guy just rolled his eyes.
« Reply #8 on: June 25, 2021, 10:26:46 AM »
Carefull with cam cover bolts as some need to be button head or you cant get the tappet caps off
« Reply #9 on: June 25, 2021, 10:36:13 AM »
They don't look close enough to me on a 400 but you are vastly more experienced so I will check before I decide to order a set.
Also can't remember if the original bolts have washers or the washer is built into the bolt - no idea what the right term is for that either. Found it on the inernet - its a flange bolt methinks!
Clearly I need to do some reading up on engineering terms.
« Last Edit: June 25, 2021, 02:01:55 PM by Macabethiele (Ted) »
« Reply #10 on: June 25, 2021, 12:09:02 PM »
Ted, the original fasteners are flanged hexagon head. That means they have a smaller hexagon size and the flange means no washer required.
« Reply #11 on: June 25, 2021, 12:29:35 PM »
May be just the 500/550 long time since i did a 400
