Author Topic: Double disc conversion  (Read 1654 times)
Offline Seabeowner
Re: Double disc conversion
« Reply #15 on: September 02, 2021, 08:39:44 AM »
Rather than this route. Anyone with experience of using replacement cast iron disc. Improved braking, warping??
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
« Reply #16 on: September 02, 2021, 12:56:52 PM »
Did it back in the 70's, found out the hard way that a disc locking the wheel with 3 inch of water on road is not a good idea plus wasnt that much better than 1 stainless and not as good as 2
Offline sprinta
« Reply #17 on: September 02, 2021, 04:18:27 PM »
I'm using the std CB750 master cylinder on my K2 with twin discs and have no issues with the travel or feel. I think you will find that it is not necessary to change the std M/C to one with a larger piston, such as the one used on the GL1000's.
However, if you feel happier with that then go ahead and fit one with a larger piston. As to using a 'modern' one (I assume newer) there will be no advantage over and earlier one that has the same piston size, though clearly a newer one may have better/newer seals but as long as the seals, and bore are in good order they should both perform the same.
« Reply #18 on: September 02, 2021, 04:47:21 PM »
I’m using the early GL1000 item as it looks ‘period’ and most of the DDC I’ve read recommend it…..we will see.
