Author Topic: Letters and numbers[emoji16]  (Read 1294 times)
Offline allankelly1
« on: August 14, 2021, 08:24:38 PM »
Hi all I have the following letters stamped on my case that refers to the main bearing shells but which letter corespondents to which colour please
Also my rods have numbers too and am I right in thinking these are bearing codes too and if whey are what colour does each number represent
Any advice welcome
Best wishes Al
Offline Deano400
Re: Letters and numbers[emoji16]
« Reply #1 on: August 14, 2021, 08:46:24 PM »
Al,
You also need to look for these markings before you can decipher the colours.
Offline Deano400
« Reply #2 on: August 14, 2021, 08:47:50 PM »
Ignore the red circles, you are looking for the yellow markings on the crank webs.
Offline allankelly1
« Reply #3 on: August 14, 2021, 08:52:15 PM »
Not very clear but under a torch they are all 1
And to be honest would not even know they there till you pointed this out
(Building a 2T is much easier)
Best wishes Al
« Last Edit: August 14, 2021, 08:55:37 PM by allankelly1 »
« Reply #4 on: August 14, 2021, 09:01:02 PM »
Your con rod weight codes look like you have three weight codes 1.3 & 2 not sure if thats original ? Ah no the weight codes are letters probably on the other side.
You need to look hard at your shells to find any remaining colour codes if you can. The crankcase codes just give you one axis on the charts. There will also be codes on the crank for the big end sizes. Quite hard to find in my case.
If you can't find any colour codes then you will need to measure the crank journal sizes and check them against the parts code charts & then Plastigauge to check the clearances if necessary using a known shell colour as a starting point..
« Last Edit: August 14, 2021, 09:35:50 PM by Macabethiele (Ted) »
Offline Deano400
« Reply #5 on: August 14, 2021, 09:11:30 PM »
Offline allankelly1
« Reply #6 on: August 14, 2021, 09:15:33 PM »
I guess these code on the back of the cases are the case bore sizes and I need to find out the crank main bearing journal sizes so for main bearing one the case is size “A” and the journal size is the number
It’s early days but want to work out now / understand  what I need to get as want to replace all shell bearings
Also I presume as all the crank webs have A1 the big ends are red?
Best wishes Al
« Last Edit: August 14, 2021, 09:19:43 PM by allankelly1 »
Offline Deano400
« Reply #7 on: August 14, 2021, 09:21:41 PM »
Your casing is marked AABBB and your crank looks like 11111 which should give you Yellow Yellow Green Green Green.
Not going to guess which rod is which from the pics but crank looks all As so A1 – Red, A2 – Yellow, A3 – Green.
Hopefully someone will confirm.
Offline allankelly1
« Reply #8 on: August 14, 2021, 09:25:34 PM »
I’m confused
I understand the big ends are all looking to be A1 but where do you get the 11111 from for the crank mains please
Big thanks for appreciation to all for this help
Best wishes Al
« Reply #9 on: August 14, 2021, 09:27:07 PM »
I have e-mailed you a copy of the excel sheet I made to help me identify the right colour codes.
Offline Deano400
« Reply #10 on: August 14, 2021, 09:29:03 PM »
The letters on the case combine with the numbers on the crank to give you the mains. The letters on the crank combine with the numbers on the rods to give you the big ends.
Offline Athame57
    • SeaWitch Artist
« Reply #11 on: August 14, 2021, 09:34:09 PM »
I don't know what is actually going on!
I brake for animals!
1978 CB400F2 called Elen.
Offline allankelly1
« Reply #12 on: August 14, 2021, 09:34:28 PM »
All is now clear the 1 on each crank web is combine with the case letter for mains
In my case A1 A1 B1 B1 B1
And for the big ends it’s the letter on the crank web This case “A” combined with the number on the rod in my case A3 A1 A2 A2
Now it’s al clear and off to record all before any marks get removed
Thanks every day is a school day
Best wishes Al
« Last Edit: August 14, 2021, 10:03:19 PM by allankelly1 »
« Reply #13 on: August 14, 2021, 09:37:25 PM »
Have you found any coloured edges on the old shells ?
Handy if you have at least some.
« Reply #14 on: August 14, 2021, 09:42:37 PM »
Well put Deano400.
