Author Topic: Steering Head Bearings  (Read 1957 times)
Re: Steering Head Bearings
« Reply #15 on: August 19, 2021, 10:00:11 PM »
You could get needle roller conversions from the US some years back but they didnt last long as the bearings only really last when they are rotating, remember the mono shock rear bears that needed changing  nearly every mot
Offline Andych
« Reply #16 on: August 19, 2021, 11:46:55 PM »
1975 CB400 - Project
1978 Yamaha SRX250 - Project
« Reply #17 on: August 20, 2021, 09:49:30 AM »
That H264815 bearing number has measurements of 26 x 48.5 x 15 as per the link below.
https://simplybearings.co.uk/shop/p554001/H264815-Narrow-Section-Steering-Head-Set-Taper-Roller-Bearing-26x48.5x15mm/product_info.html
I think you are onto something here it's the part number not the actual bearing size!
Either way you can get the right upper taper roller that's not too tall.
Out of interest nobody appears to list a 26 x 48 x15 bearing on the couple of sites I have checked on.
« Last Edit: August 20, 2021, 04:12:12 PM by Macabethiele (Ted) »
« Reply #18 on: August 20, 2021, 02:28:13 PM »
Thats because the taper rollers that fit the bikes are not a standard sizr
Offline AndyD
« Reply #19 on: August 20, 2021, 04:32:04 PM »
Update on the Wemoto bearings.
Had another play with the upper set - popped a couple of loose ball bearings in to see how it would build up if the caged bearings did fit properly.
The race seems correct and as original but the cone is quite different and when fitted the set is several mm higher than standard so not much use.
Shame as the bottom set seems perfect and the top would be if the cage fitted and the cone was the same profile as original.
I just wonder why someone has put together all these varieties of replacement bearing sets that just aren't correct.
Wemoto are looking into this so maybe the supplier can explain / correct things.
Cheers,
Andy
« Reply #20 on: August 20, 2021, 05:16:32 PM »
(Attachment Link) (Attachment Link)
Cheers,
Andy
This was the set of plain rollers I bought when I could not find a suitable upper taper. At £15 for the pair not too expensive. I'm pretty sure you will be able to buy just the upper bearing if you contact the firm. The dimensions given I can confirm were accurate. Might be worth sending a PM to 4wDaz he sourced me some Primary Drive bearings at a great price.
https://www.ebay.co.uk/itm/324462234796
« Reply #21 on: August 22, 2021, 04:07:40 PM »
Although I'm sticking with my existing mixture of bearing types I have purchased the top taper roller bearing from Pyramid parts and can confirm they are the same dimensions including the all important height at 15 mm. So looks like anyone can fit taper rollers if they want to on a 400/4. I'm thinking of fitting some sort or shield/deflector to reduce water reaching the lower races. I'm sure with it having a 3 mm spacer a better seal could be fitted.
Offline Athame57
    • SeaWitch Artist
« Reply #22 on: August 22, 2021, 08:08:02 PM »
Which size would I need to order from them on their drop menu? https://pyramid-parts.com/products/ssbmain
I brake for animals!
1978 CB400F2
« Reply #23 on: August 22, 2021, 08:33:51 PM »
For the top one it's 26 x 48.5 x 15 you have options for the lower one they list  for 30 x 50 x 14 with an appropriate spacer (they do list one at only 13 mmm tall). Quite a few sellers make bottom roller bearings that fit so other makes are available.
This link is for individual bearings rather than a kit.https://www.ebay.co.uk/itm/290781743090?var=590082068373
Kit looks like BR29 & it has seals!    https://pyramid-parts.com/products/ssbmain?variant=40126403591
Helpful fitting guide too.https://pyramid-parts.com/pages/steering-head-bearings-fitment-guide
Please double check my findings before you order.
« Last Edit: August 22, 2021, 08:45:15 PM by Macabethiele (Ted) »
