Other Stuff > Desperately Seeking!!
CB72 CB77 Main stand Return spring or Dimensions ... available in UK
AshimotoK0:
I got this back from a guy on VintageHondaTwins forum:
"The CL77 spring which looks the same is 85 mm length and the spring is 18 mm thickness. The wire diameter is 2.6mm.
Part # 50522-268-000 was used on your bike along with the CL72 and CL77, so it is the same spring I quoted above in size".
I have got a spring 18mm OD & 2.6mm wire but a few turns too long so may have a go at shortening it.
rosco:
Hi Ash My measurements are the wire thickness 3mm Diameter of spring 17mm Number of coils is 18 As the bike is on its stand i cannot accurately measure length If you want this measure let me know and i will take it off measure and send you a picture Ross
AshimotoK0:
--- Quote from: rosco on February 18, 2022, 09:44:38 AM ---Hi Ash My measurements are the wire thickness 3mm Diameter of spring 17mm Number of coils is 18 As the bike is on its stand i cannot accurately measure length If you want this measure let me know and i will take it off measure and send you a picture Ross
--- End quote ---
I think the CA77 is a different part number to the CB72/77 Ross .. but still investigating. Looks similar though.
Navigation
[0] Message Index
[*] Previous page
Go to full version
