Author Topic: Twin disc set up.  (Read 1696 times)
Offline Bro550F
Twin disc set up.
« on: March 14, 2022, 01:05:03 PM »
Does anyone have the parts for sale or can point me in the right direction to buy what I need for a twin disc set up on my CB 550 F2 , also regarding braided lines and M/C swop if deemed necessary.
Thanks.
Re: Twin disc set up.
« Reply #1 on: March 14, 2022, 06:41:35 PM »
Theres a really good thread posted by Bryan in Aladdins cave showing you the process in depth and the alterations you'll need to perform. Basically you'll need another caliper, disc and mounting hardware, modified speedo drive plate but with regard to your hoses, I'm getting my hoses made up to fit once I know what bars I'm gonna run but any decent hose manufacturer will make you a set. Such as Goodrich, Hell or you can make your own if you buy all the bits from one of the mentioned firms.
Ideally you'll need a master cylinder that is of a better capacity  to push the fluid into both lines with the  same pressure, some have used a honda Goldwing item as they look the same but I cant remember which model, mght be the GL1200 but cant be sure. Hondaman sell good alternatives as does a great deal of the after market suppliers but if your not fussed about looks, most modern-ish, M/C's will be sufficient but its all down to the piston size and there are better people on here to discuss that with as I'm not 100% 'bob on' with the theory as I havent got to the front end yet so havent done any homework on it I'm simply parts hoarding to hit the ground running when I get round to them.
Offline Bro550F
« Reply #2 on: March 16, 2022, 10:48:56 AM »
Thanks for your reply. I'll check it out and start gathering the bits.
« Reply #3 on: March 16, 2022, 06:26:35 PM »
Just had a quick look, go to aladdins cave and scroll down to 550. enlarge and look for
CB500/550 Dual Disc Converstion Part 1 (Black Square Motorcycles)
Its all on there with photo's. Enjoy ;)
« Reply #4 on: March 16, 2022, 06:37:40 PM »
I have a few spare discs Bro, if you need one.
« Reply #5 on: March 16, 2022, 08:42:20 PM »
The black square one is wrong in parts, especially about the speedo drive. I know there is one i put up with pics of how to do speedo drive.
I have the file i wrote as a pdf but cant seem to attach it. If you want a copy email me your email to the address in my profile and i will send it
« Last Edit: March 16, 2022, 09:00:37 PM by Bryanj »
Offline Bro550F
« Reply #6 on: March 17, 2022, 09:26:01 AM »
Would this master cylinder be a good replacement for twin discs, do you think?
https://www.ebay.co.uk/itm/175114757262
« Reply #7 on: March 17, 2022, 09:38:35 AM »
Should be fine and work well. It's largely preference as to what you use in the feel you're after.
These standard dimension mc will have increased travel but with less hand pressure needed to give braking when used with a twin setup. It'll feel more like a modern brake regarding the power it can give you in use.
The larger reservoir type (goldwing) has increased fluid capacity to get from one service interval to the next with the pad wear a goldwing would give. Largely in motorcycle systems now they don't do that with straight capacity, just more frequent checking of fluid level, usually with a clear pot to make it easy.
Offline sprinta
« Reply #8 on: March 17, 2022, 10:04:26 PM »
You will find that the std master cylinder works perfectly OK on a twin disc set-up.
That is what I have done when I did the twin disc set up for my CB750K2 and it works fine.
So if you have a good std one it might be worth using that first before replacing it?
You might find this link useful, though it is for the early K series some of the basic detail in what is required is similar.
http://www.sohc.co.uk/index.php/topic,21171.0.html
« Last Edit: March 17, 2022, 10:11:33 PM by sprinta »
Offline Bro550F
« Reply #9 on: March 18, 2022, 06:22:51 AM »
Thanks for the info guys.
Oddjob and Bryanj I have sent emails, thanks.
« Reply #10 on: March 18, 2022, 06:40:11 AM »
This is the Master cylinder i used on a disc conversion >>>  https://www.davidsilverspares.co.uk/CB750F2-(Single-overhead-cam)/part_126550/
« Reply #11 on: March 18, 2022, 01:54:03 PM »
Not got any emails Bro
« Reply #12 on: March 18, 2022, 03:05:24 PM »
Me neither
« Reply #13 on: March 18, 2022, 03:13:44 PM »
I used this un.
« Reply #14 on: March 18, 2022, 04:08:49 PM »
The Same master cylinder by George. The wonders of UJM products.
