Other Stuff > Desperately Seeking!!
Cb550 k3 outer carb rubber
<< < (2/2)
fourfive:
--- Quote from: Bryanj on June 05, 2022, 07:40:34 PM ---Its the angle of the outers that is different to fit the pd carbs
--- End quote ---
I've got a pair of earlier inlet manifolds from a f1, these look deeper than the k3 so would make the carbs sit closer to the air box. Am I right in thinking the f1 carb to air box rubbers would then fit? Or is it not that simple.
I'd like to keep things original if possible
Bryanj:
Only if you fit the F1 carbs as well and the carb to manifold rubbers
paul G:
--- Quote from: Seabeowner on June 05, 2022, 07:07:46 PM ---That's Paul Gabor.
email  mybluebike2004@yahoo.com
Bought the two outer ones in 2016. OK, but you need extra care with them.
I wondered about using the boots from the earlier bikes and moving the chamber forwards. Maybe making an extra ring between air filter box or modding the whole mounting.
--- End quote ---
I had a set off him for the K3 really good quality.
He was a bit reluctant to post to the UK due to a couple of bad experiences but mine arrived OK.
fourfive:
--- Quote from: paul G on June 06, 2022, 07:57:52 AM ---
--- End quote ---
--- End quote ---
I've ordered a set from the above, thanks for the replies
fourfive:
--- Quote from: fourfive on June 07, 2022, 11:39:58 PM ---
--- End quote ---
--- End quote ---
--- End quote ---
Update
Rubbers arrived today, very Good quality
Navigation
[0] Message Index
[*] Previous page
Go to full version
