SOHC.co.uk Forums > CB750
Under-geared F1?
StealthDJ:
--- Quote from: Skoti on June 27, 2022, 09:14:41 PM ---Previous owner fitted a smaller rear sprocket to my 1976 F1, it pulls 60mph @ 3500rpm.
It's nice and relaxed and pulls top gear fine when two up touring loaded with camping gear etc.
So yes I can recommend a smaller rear sprocket.
Hope this helps.
(Photo taken on route to Honda4Fest earlier this month)
--- End quote ---
Good to know, thanks - any idea what size sprockets / number of chain links are on it?
Skoti:
I think the chain has 98 rollers, but will double check today and
I'll also count the rear sprocket teeth.
Skoti:
Hi,
Just checked my F1 gearing for you.
Rear sprocket - 43t
Rear chain - 98 rollers (49 links)
Also I'm sure the front sprocket is still the standard size.
Hope this helps
Skoti
StealthDJ:
--- Quote from: Skoti on June 28, 2022, 10:17:47 AM ---Hi,
Rear sprocket - 43t
Hope this helps
Skoti
--- End quote ---
Thanks for checking - that's definitely quite a jump from the standard 48 rear sprocket and more than I'd have considered going otherwise. I'll have to get the calculator out and figure out the ratios... :)
Skoti:
Hi,
Just been out on my F1 to a classic bike and cafe racer meeting for a look around.
And I've a confession to make because my earlier statement about gearing was bollocks.
"Previous owner fitted a smaller rear sprocket to my 1976 F1, it pulls 60mph @ 3500rpm".
Today I doubled checked and it actually pulls 55mph @ 3500rpm, so sorry if I misled anyone...
Navigation
[0] Message Index
[*] Previous page
Go to full version
