Other Stuff > Desperately Seeking!!
CB500 number plate / light bracket 84701-323-600B
SPR:
--- Quote from: 3scs on August 06, 2022, 05:55:44 PM ---Not quite sure what this is off it was fitted to my 550k3 when I bought it if it’s any use
--- End quote ---
Sent you a pm
SPR:
--- Quote from: Oddjob on August 06, 2022, 09:04:11 PM ---That should fit. Both the smaller and larger rear lights are spaced the same bolt hole wise Bryan so they'll both fit.
--- End quote ---
Great info - thanks !
SPR:
Was doing a little research and found it is the same bracket as a GL1000 and found one on eBay.ie
Looks pretty rust free and the number plate bracket part especially seems to still be smooth with just surface rust ...
Better than the £300+ for a non original :)
Simon
Navigation
[0] Message Index
[*] Previous page
Go to full version
