Author Topic: Has anyone used these coils?  (Read 2270 times)
Offline beardylondon
1976 CB550 K2 (USA import)
Re: Has anyone used these coils?
« Reply #31 on: April 16, 2024, 05:35:51 PM »
From China
« Reply #32 on: April 16, 2024, 05:38:03 PM »
True, but it “might” be a good? 😌
« Reply #33 on: April 16, 2024, 05:41:47 PM »
Indeed, it may be good.
« Reply #34 on: April 16, 2024, 05:58:05 PM »
Yes I've bought from Chinese sellers in the past.
My issue is any warranty is generally worthless also returning goods often has costly  hurdles to overcome.
If I can buy from a genuine UK based firm with a known returns policy with good feedback I buy from a UK firm even though it might be a few quid extra, not one of the sham fronts that you find on eBay that is some sort of warehouse with no UK phone number.
Online martin_uk
« Reply #35 on: April 16, 2024, 08:37:12 PM »
My general experience with Chinese parts and tools is not good.
The exception is well known brands with a good reputation.
But as they say you pays your money and takes your choice......
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
« Reply #36 on: April 16, 2024, 08:49:07 PM »
Thanks all, probably go for the previously mentioned ones, which don’t come with plugs, but are already being used by Ted
« Reply #37 on: April 17, 2024, 11:13:28 AM »
I emailed this seller to ask what the primary resistance of these is, knowing I won't buy, but I was interested, and this is their response:
"primary resistance is ?
we can resistance
thank you"
This set seems too cheap to be any good?!
https://www.ebay.co.uk/itm/195978773341?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=a5qr2fnqtcu&sssrc=4429486&ssuid=wmWanCu3SsS&var=&widget_ver=artemis&media=COPY
« Reply #38 on: April 17, 2024, 11:40:58 AM »
Just found this information that I posted here a while back. I think I spelt Hendler wrong.
"I fitted these (Hedler) as they are probably a temporary measure until I restore my originals.
They are Primary  5.11 Ohms - S 17.55 Ohms  made by Hedler the spec is on Hedlers website p/n 540612H
I did not use the screws shown in the picture mounted them in the original saddle at each end.
I switched the wiring so the poitive marked terminal was on the ignition feed side."
https://www.hendler.co.uk/category/ignition-coils
Although this is the trade site you can still search the part number & find the coil specifications.
« Last Edit: April 17, 2024, 11:46:54 AM by McCabe-Thiele (Ted) »
« Reply #39 on: April 17, 2024, 01:10:03 PM »
funnily enough I was looking at Hendler's website this morning and found them on ebay for £24.49, same part number
https://www.ebay.co.uk/itm/176189478084?
« Reply #40 on: April 17, 2024, 03:57:29 PM »
Yes that's the price each I think, mine were about £59.50  for the pair in 2022 so they will have gone down a tad.
Price updated.
bike.stop.shop are registered as SINo PANGAEA TRADING LTD based in Derbyshire.
« Last Edit: April 17, 2024, 04:47:29 PM by McCabe-Thiele (Ted) »
Offline Brocky2
« Reply #41 on: April 23, 2024, 07:21:09 AM »
Hello,
I bought a pair of coils from EBay for £37! They’re bound not to work!
I’ve just fitted them. They’re working fine so far after an ‘extensive’ 25 mile test.
The only problem is (as someone else here stated) the mounting holes are 90mm apart and the  standard fitting on my 550k3 is 100mm apart so you need to make up two little steel brackets. Measurements, 11mm wide, 28mm long with two 6.5mm holes with centres 10mm apart and 9mm from each end. Also as they have male spade connectors you have to make up 4 wires (2x female spade to male bullet black with white stripe and 2x female spade to female bullet one blue and one yellow). They need to be about 250mm long. I don’t think the coil connections are polarised so I just wired them the same way as each other.  I suppose we’ll see how long they last.
I was also quite pleased I did this as the yellow wire connection just fell apart and was due to fail. Good luck with it.
Offline deltarider
« Reply #42 on: April 23, 2024, 08:16:09 AM »
Why not indicate which you bought? We're in the dark.
« Reply #43 on: April 23, 2024, 10:42:42 AM »
BTW I went for these Hedler ones, as recommended by Ted and also Ash said the higher resistance of these is better than cheaper versions.
They are yet to arrive, but I will report back.
https://www.ebay.co.uk/itm/145665457928
« Reply #44 on: April 23, 2024, 12:54:09 PM »
Hello,
Is the primary resistance quoted?
A link to the actual item would help.
« Last Edit: April 23, 2024, 01:28:58 PM by McCabe-Thiele (Ted) »
