Author Topic: Grease Nipple Removal  (Read 1956 times)
Offline SPR
  • 1972 500/4 K1
« on: October 02, 2022, 12:40:30 PM »
Afternoon
Before I send my spare casings away for polishing I thought it would be good to remove the grease nipple ......... maybe a daft question - but how does it come out
Simon
Re: Grease Nipple Removal
« Reply #1 on: October 02, 2022, 01:26:11 PM »
If you look inside the opening you can see the outlet that the nipple uses, a thin screwdriver or piece of metal can be used to poke it out from underneath. It's tight but doable, did this just the other day.
How much are they charging for polishing that, it's not an easy casing to do, lots of recesses and I'd be surprised if you don't get it back with some dull areas.
A really good polisher should be able to do it all and get it consistent, areas like the small part forward of the gear lever hole look to be contaminated with oil/dirt/grease and it's those that cause a lot of problems. If you look at it the surface looks blemished, like it has a small rash, that's the contaminants sitting just below the surface.
Offline SPR
  • 1972 500/4 K1
« Reply #2 on: October 02, 2022, 03:37:48 PM »
Cheers - will get a screwdriver and have a go
I've been quoted £130 for the 3 covers
Simon
« Reply #3 on: October 02, 2022, 03:45:03 PM »
Thats quite cheap, have you seen anything else they've done?
Offline SPR
  • 1972 500/4 K1
« Reply #4 on: October 02, 2022, 03:54:11 PM »
Only photos
I'm waiting on a price from another company to compare
« Reply #5 on: October 02, 2022, 04:02:55 PM »
Might be a sooper dooper deal but just sounded a bit cheap. Either that or Ive had me skirt lifted ;D
« Reply #6 on: October 02, 2022, 06:52:31 PM »
I see Philpotts quote £100 to do a pair of fork sliders, which I thought very reasonable considering the amount of work involved.
I've heard of £750 just to polish the barrels on a GT750. £130 for 3 cases is very cheap, I'd expect a poor job for that TBH but you never know until you try.
Offline SPR
  • 1972 500/4 K1
« Reply #7 on: October 02, 2022, 07:06:23 PM »
TBH if they get it anything like without contamination then it will be better than those currently fitted - then I can take my time and look at maybe doing them myself sometime in the very distant future
« Reply #8 on: October 02, 2022, 09:05:40 PM »
I was wearing a similar skirt and was quoted £160 for alternator, clutch and sprocket cover. TBH I was quite happy with that and the suppliers work satisfies my cosmetic eye. However, inspired by Oddjob I’m going the DIY route. Bet I regret it😁
« Reply #9 on: October 03, 2022, 12:20:17 AM »
I bet you do! ;D
Can i have my skirt back if you've finished with it Phil? ;D
« Reply #10 on: October 03, 2022, 02:53:33 AM »
Hey, you borrowed that skirt off me, bloody Yorkshire tealeaves.
« Reply #11 on: October 03, 2022, 06:28:54 PM »
If you want a professional job, then send it to the professionals. Briteworx.co.uk
To achieve a pro finish you will need a motor 1KW minimum, a ton of mops , soap bars, lime and safety equipment. The part also needs to be in good order to start and most professional polishers vapour blast the part first to remove any corrosion and contaminates  ;)
« Reply #12 on: October 03, 2022, 06:34:00 PM »
https://briteworx.co.uk/cgi-sys/suspendedpage.cgi
Website is down or dead when I tried it.
« Last Edit: October 05, 2022, 02:05:03 AM by McCabe-Thiele (Ted) »
« Reply #13 on: October 03, 2022, 06:49:57 PM »
He's (Harry Overton) is on Facebook Ted. He's not far from you in Swadlincote. His work is absolutely stunning. A master of his art. 07861778841
« Last Edit: October 03, 2022, 06:52:05 PM by Nurse Julie »
« Reply #14 on: October 03, 2022, 07:00:10 PM »
Got to disagree with that Graham, some are good, some are cowboys who claim they can do a decent job but do the exact opposite. I'd match some of my polishing up against any pro, I don't have half of the stuff you list and I've got great results with casings that a lot of pro's wouldn't even have touched. The end results depend a LOT on the amount of effort you put in BEFORE it evens goes near the mop, the more effort, the better the result IMO. I've just spent 5-6 hours on one float bowl because it had been chromed and even having the chrome professionally removed, it didn't remove all of it, there were patches where the nickel was still attached and that's a huge problem to remove. Took me many hours to sand it off, only done 3 bowls up to now and not looking forward to doing the last.
I'm going to attempt to restore an old 550 alt casing I found in my last job lot buy, it's been done the road HARD, literally loads of gravel rash etc, deep gouges and even some of the lettering like the Made In Japan has been affected, I want to see how good I can get it, I like doing stuff like that, just to challenge myself. If it turns out ok I'll sell it, if it doesn't I'll junk it. It's only time, I've got quite a bit of that on my hands at present.
BTW Ted, link doesn't work.
