Author Topic: cb400/4 front brake  (Read 718 times)
Offline gaz172
cb400/4 front brake
« on: February 02, 2023, 09:18:40 PM »
On my 400/4 i did away with the front brake switch and put a stainless goodridge hose from master cylinder to caliper and it passed mot's in the eighties. i am now using it like that now but have been told this is illegal does anyone know if this is true as i was thinking of doing the same with the one i am working on now.
1976 Honda 400/4 x2
1981 Suzuki gs1000e
1981 suzuki gs1000g
2022Benelli imperiale
2010 Ducati 1198s
1994 ducati 600 monster
1958 Matchless 350
1953 matchless g9
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: cb400/4 front brake
« Reply #1 on: February 02, 2023, 09:28:55 PM »
Gaz, surely the issue is not one of legality, but rather safety? Bikes are dangerous enough without being rear-ended for the sake of a switch.
« Reply #2 on: February 02, 2023, 09:44:12 PM »
Any bike manufactured before 1986 only needs EITHER a front or rear switch, not both.
But personally, I think the use of either brake should go through a switch, it's basic safety common sense.
4.3.2. Switching
Motorcycles first used on or after 1 April 1986 must have a stop lamp that switch on from both brake controls. However, a small number of motorcycles first used from this date were approved with the stop lamp switching on by only one control
« Last Edit: February 02, 2023, 09:54:13 PM by Nurse Julie »
« Reply #3 on: February 02, 2023, 10:19:07 PM »
You can get these or similar
From here to run the same arrangement through this and position it where convenient https://www.demon-tweeks.com/mocal-in-line-brake-light-switch-sender-adaptor-mochar3/
« Reply #4 on: February 02, 2023, 11:03:17 PM »
You can get a banjo bolt with switch built in
Offline gaz172
« Reply #5 on: February 03, 2023, 06:02:19 PM »
4.3.2. Switching
  Thanks julie thats what i thought. always worth checking
1976 Honda 400/4 x2
1981 Suzuki gs1000e
1981 suzuki gs1000g
2010 Ducati 1198s
1958 Matchless 350
1953 matchless g9
« Reply #6 on: February 03, 2023, 06:42:02 PM »
Ebay item 203463672328
Offline gaz172
« Reply #7 on: February 03, 2023, 09:25:09 PM »
thanks might give that a try
1976 Honda 400/4 x2
1981 Suzuki gs1000e
1981 suzuki gs1000g
2010 Ducati 1198s
1958 Matchless 350
1953 matchless g9
