Author Topic: Does this need replacing oval mounting holes?  (Read 728 times)
« on: February 07, 2023, 12:13:35 PM »
Whilst starting to clean up the front brakes I noticed the top calliper pivot arm bracket had visibly oval mounting holes - one is much worse than the other.
The ovality is visible from the rear as well.
The long pivot pin was nice & free - could this have been caused by this having been stuck previously?
Will it need replacing if they are available?
.top bracket by Macabe Thiele, on Flickr
« Last Edit: February 07, 2023, 12:18:31 PM by McCabe-Thiele (Ted) »
Re: Does this need replacing oval mounting holes?
« Reply #1 on: February 07, 2023, 05:49:44 PM »
As long as the brake pivot pin hasn't got any play in it you'll be fine. The mounting holes give you a bit of adjustment to line it up and won't move once everything is tightened up. 👍
« Reply #2 on: February 07, 2023, 07:13:21 PM »
I did wonder if the torque on the bolt would hold it nicely in place.
Was the pivot arm originally painted or polished alloy?
« Reply #3 on: February 07, 2023, 07:15:55 PM »
Painted, like the casings Ted.
« Reply #4 on: February 08, 2023, 11:39:12 AM »
My existing calliper arm is polished - its cleaned up quite quickly on my buffing wheel (not to Kens standard)- I think I prefer it painted as on my 400 so good to hear they were painted originally.
« Reply #5 on: February 08, 2023, 12:00:32 PM »
Painted black Ted…..not nut brown😁
« Reply #6 on: February 08, 2023, 12:30:38 PM »
Have you seen that 500 link I posted today Phil ?
It's on the Hi from Essex thread I might be a tad colour blind but sure the bodywork is Brown.😁😁😁
« Reply #7 on: February 08, 2023, 03:17:13 PM »
Ha, ha. Just been for a peak. Not my cup of tea as they say..😁
How’s the bike coming along. The recent photos show some promise.
« Reply #8 on: February 08, 2023, 04:50:08 PM »
Hi Phil I'm currently putting the front suspension together but tbh the cold weather slows me down. Once I have fitted the brakes, mudguard & wheel back in I need to turn the bike round on the stand plus turn the bike stand round as well. This is to make fitting the engine easier later in the year.
I need to remove the tank badges etc to get the bodywork off to the painter by the middle of this month.
I need much warmer weather then to start on the engine/gearbox internals - I do not want to bit & bob on the engine like I can with frame stuff over the winter.
« Reply #9 on: February 08, 2023, 05:33:07 PM »
OOI, how do you intend to paint the caliper? I ask simply as the HT paint I used cracked on assembly. I tried and failed a couple of times. In the end I etch primed, mist coated then two top coats, cured in the oven and hey presto it worked.
I was wondering if others had a fail safe solution?
« Reply #10 on: February 08, 2023, 05:41:10 PM »
I'll most likely powder coat mine Phil or may go for ceramic coated instead.
Offline peterengland
« Reply #11 on: February 08, 2023, 06:09:10 PM »
I just rattle canned mine and it's been fine ever since!
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
« Reply #12 on: February 08, 2023, 07:34:04 PM »
Painting in February not sensible due to garage temperature.
