Author Topic: Yoshi pistons  (Read 529 times)
Offline hiltonig
Yoshi pistons
« on: April 13, 2023, 01:09:12 PM »
Just a question anyone fitted a set and did it make much difference ? Are the yoshi  pistons better than Oem ? Not sure about the cam as just after a bit more torque
Offline Rozabikes Tim
Re: Yoshi pistons
« Reply #1 on: April 13, 2023, 02:00:26 PM »
If you are after some and not committed I have a set of unused Cruzin Image 460cc with gasket..... Good quality pistons that many on here use.
Re: Yoshi pistons
« Reply #2 on: April 13, 2023, 04:46:41 PM »
The cam needs different ign timing and gearing to get the best as there is more power higher up but you loose at the bottom, at least thats what i found in the 70's.
Pistons usually raise the compression
Offline ka-ja
  • ken
  • yoshi 460
Re: Yoshi pistons
« Reply #3 on: April 13, 2023, 07:54:39 PM »
Yoshi 460cc pistons increase mid range torque/power, the yoshi cams put power back up the rev range, I run the 460 pistons with the 1/2 race cam.
nice bike,nothing in the bank
