Author Topic: Looking for a tail light like this that will fit original fender  (Read 576 times)
Offline alexdecker
Hey all
Saw this beautiful bike on the American forum. I am getting a new rear fender soon, as there are massive rust holes in my own. Instead of the stock taillight, I am looking for something a little more discreet like this, but if possible will still fit without modding fender/drilling holes.
Does anyone know of anything nice I could go for?
Re: Looking for a tail light like this that will fit original fender
« Reply #1 on: June 19, 2023, 08:25:05 AM »
Looks a bit like a lucas lens on a home made bracket
« Reply #2 on: June 19, 2023, 08:52:29 AM »
Or you could do this -  some might call it vandalism but the lamp was cheap enough all LED's
I will post a photo of it on the rear mudguard later.
lamp 1 by Macabe Thiele, on Flickr
« Last Edit: June 19, 2023, 08:55:15 AM by McCabe-Thiele (Ted) »
« Reply #3 on: June 19, 2023, 09:21:29 AM »
Here you go Alex, this is the same fitting. I installed on my Triton when I built it in 2000:
https://www.classicbikeshop.co.uk/universl-classic-style-stop-tail-light-c-w-housing.html
I changed the actual light fitting last year when I restored the bike. I swapped out the light fitting (but not the mounting) for a Motone custom LED rear light that looks exactly the same as the Lucas type but is obviously a lot brighter.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #4 on: June 19, 2023, 09:25:43 AM »
« Reply #5 on: June 19, 2023, 09:29:42 AM »
Alex you can find lots of inexpensive rear lamps on the likes of e-bay - unfortunately most of them have different bolt centres so I cut the new lamp bracket down then drilled some extra holes to make it fit.
.https://www.ebay.co.uk/itm/354419352010
« Reply #6 on: June 19, 2023, 11:51:22 AM »
https://www.vehiclewiringproducts.co.uk/c-1-home/c-82-motorcycle-parts/c-152-lights
It looks like my Triumphs rear light - vehicle wiring products stick them along with a few other classic styles. My suggestion would be to make a backing plate/ adapter if you don't want to drill the mudguard.
« Reply #7 on: June 19, 2023, 01:12:38 PM »
The big advantage with the fitting from Classic Bike Shop is the two mounting bolts are hidden by the chrome cover of the tail lamp so it looks 'clean'.
1976 Honda 400/4
« Reply #8 on: June 19, 2023, 01:31:10 PM »
Photos of the fitting on the Triton, you can see the fixings are hidden (I rubber mounted the fitting simply becuase its a vibrating Triumph motor in the frame!).
The Motone LED replacement light is a direct replacement for the original.
1976 Honda 400/4
« Reply #9 on: June 19, 2023, 01:33:14 PM »
Can anyone identify those tyres/ sizes? They look really nice without being too wide or no brat-style. I'm assuming the wheels are standard but possibly not if they have new rims, which seems to be the case.
« Reply #10 on: June 19, 2023, 02:04:03 PM »
They are alloy Excel rims Andy and appear to be wider than standard. I tried to enlarge the photo to see the tire size but impossible to see.
1976 Honda 400/4
Online Oddjob
« Reply #11 on: June 19, 2023, 02:35:58 PM »
The front looks to be a 100/90 x 18 which means he's fitted an 18" rim onto a 550, probably means his speedo will be out. The back is most likely a 110/90 x 18 to match the front wheel. Those roughly equate to 4.10 front and 4.25/85 rear in old sizes. Which is what I'll be fitting as my rims are larger section that standard rims.
Online Oddjob
« Reply #12 on: June 19, 2023, 02:37:39 PM »
One thing to bear in mind Alex, there is no way a perspex number plate will fit on that rear light, it's too close to the guard and needs to be bent a little to clear the guard, not a problem IF it's at the base of the guard but right under the seat you'd need a metal plate.
Offline alexdecker
« Reply #13 on: June 19, 2023, 04:52:32 PM »
That's a good point! I was thinking of finding a rear fender that was slightly bobbed, so hopefully the plate would have clearance (and sorta act a little like a prolonged mudguard I guess). I haven't had any success finding a pre-bobbed rear fender that will fit a CB550 without straying too much from the factory look. And I don't have the skills to produce one of my own. My license plate is metal though, so could probably bend it slightly and get away with that and a Vietnamese rear fender :)
