Author Topic: Rear wheel hub fitting  (Read 1343 times)
Offline Athame57
    • SeaWitch Artist
Re: Rear wheel hub fitting
« Reply #15 on: July 07, 2023, 08:42:42 PM »
Happy birthday Gary, remember when these where new?  ;D
I brake for animals!
1978 CB400F2 called Elen.
« Reply #16 on: July 07, 2023, 10:57:54 PM »
Not sure if it helps but I had issues with the wrong spacers on my 500 K0 frame - the wheel was to the right of centre I have now fitted as below standard ones in SS from Max.
My brake side spacer is 45 mm - chain side is 32 mm I believe if you have 500 hubs they are the standard size.
« Reply #17 on: July 08, 2023, 10:38:00 AM »
The distance on the swinging arm at the ends should be 242  ;)
« Reply #18 on: July 08, 2023, 10:53:37 AM »
Not that it needs confirming - fwiw my rear forks are 242 between the ends also.
Offline gary123
« Reply #19 on: July 08, 2023, 11:13:21 AM »
Thanks for all the info (and birthday wishes0
Swing arm is 242
Left spacer is 32
Right is 50 so that must be the problem. I do have others but not a 45.
Anybody got a manky old one they want to sell ? I know stainless are available but I was going to paint it so seems a bit over kill. [ Guests cannot view attachments ]
« Reply #20 on: July 08, 2023, 12:13:35 PM »
I think I might have one Gary but away until Friday ‘Oop Norf’.
I’ve got a load in the drawers at home in the shed.
« Reply #21 on: July 08, 2023, 12:22:13 PM »
I don't have any the right size as mine were incorrect when I bought the bike.
Offline gary123
« Reply #22 on: July 08, 2023, 12:27:02 PM »
Well thanks guys, but I just found one. Ted I also found that one you kindly offered. I really must get more organised Ive got stuff all over the place.
« Reply #23 on: July 08, 2023, 12:58:28 PM »
It sounds nerdy but I made an Excel Spreadsheet with the location & contents of all my parts - I even turn the item description into pale grey print  when I have fitted the part or it's on my bike ramp - took me a couple of hours over a couple of days to do the list.
I still sometimes mislay an item as I was initially lazy with sub-box contents - I'm retired so have plenty of admin time on my hands.
I print a copy off every few weeks that I use in the garage then update when I have made lots of progress or moved stuff into parts grouped boxes etc. It has saved me hours most weeks as I can usually go straight to the right shelf & box.
« Reply #24 on: July 08, 2023, 01:01:15 PM »
Yeah, but you’ve taken all the fun out of it Ted!
Just think of the ‘muttering’ you’re missing out on,what a waste
Offline MCTID
« Reply #25 on: July 08, 2023, 01:05:31 PM »
QUOTE: 'I have parts all over the place'............some of you are just lightweights ! LOL.
« Reply #26 on: July 08, 2023, 01:59:37 PM »
Kin’el!
« Reply #27 on: July 08, 2023, 02:13:38 PM »
Swing arm is 242
Left spacer is 32
Anybody got a manky old one they want to sell ? I know stainless are available but I was going to paint it so seems a bit over kill. (Attachment Link)
Put the 50mm in a lathe and take 5mm off  ;)
Offline gary123
« Reply #28 on: July 08, 2023, 02:17:43 PM »
Swing arm is 242
Left spacer is 32
I cant be trusted with a spanner, so a lathe is a real no no. :)
« Reply #29 on: July 08, 2023, 02:21:15 PM »
Swing arm is 242
Left spacer is 32
You know what the problem is now, carry on with the wheel building  ;)
