Author Topic: Round seals and hexagon bowls...  (Read 674 times)
Offline Athame57
    • SeaWitch Artist
« on: August 22, 2023, 02:50:50 PM »
See picture attached. Is there actually an easy way of making these round float bowl seals sit in the pentagon groove of the float bowl,  ::) obligatory red rubber grease has been applied. I'm ready to scream myself....help!   :o
I brake for animals!
1978 CB400F2 called Elen.
Re: Round seals and hexagon bowls...
« Reply #1 on: August 22, 2023, 02:57:57 PM »
If its not working for you with the red rubber grease George, clean the O rings and put a small dab of superglue in each corner of the float bowl, that will hold it. Red rubber grease usually sticks it on place though.
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: August 22, 2023, 03:10:47 PM »
Thanks Julie
Having mucho cursing, sweat, tears and toil I got the first one on.  ;D Must go get some super glue though.
« Reply #3 on: August 22, 2023, 03:28:20 PM »
I also coated my O rings with some Red Rubber grease then it stayed on the carb part bowl as Julie has said.
Not excessive just enough to wet all of the seal - once in the recess I just wiped off any excess with my fingers.
« Reply #4 on: August 22, 2023, 04:09:24 PM »
I must say the float bowl orings I tested when I was sourcing my orings for the carbs fitted with no grease or adhesive at all. Just pressed into place and stayed there. Get the correct size and you don't seem to have that problem.
Offline Athame57
    • SeaWitch Artist
« Reply #5 on: August 22, 2023, 04:47:44 PM »
No, I got them to fit in the end, but it was such a pain. Julie wouldn't be sending me the wrong size btw.  ;)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #6 on: August 22, 2023, 05:01:31 PM »
Mine were much easier when I stretched them a little, plus some grease
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #7 on: August 22, 2023, 05:58:38 PM »
That is interesting Ken, my 400 came with a lot of new parts including the float bowl rubber type seal - they fitted dry without issue - they were Keyster iirc that do not get a good press here.
When I rebuilt my spare set of 400 carbs earlier this year I had to use Red Rubber grease to hold my O ring seal in place in place.
Online Mikep328
« Reply #8 on: August 22, 2023, 06:49:18 PM »
I had the same experience with the Orings as ODDjob - I got the Oring set from Nurse Julie when rebuilding my carbs a couple of weeks ago and they held themselves in the bowl grooves with no need for any grease/glue.
Offline Athame57
    • SeaWitch Artist
« Reply #9 on: August 22, 2023, 07:11:11 PM »
Maybe I'm no good at it.  ;D
« Reply #10 on: August 22, 2023, 07:19:55 PM »
Helps if you have nerves left in your thumbs, unlike me!
Online Mikep328
« Reply #11 on: August 23, 2023, 08:17:48 AM »
Maybe a function of any lube or residual dirt still in the grooves?
When I pulled my carbs apart there was all sorts of hardened red "stuff" in the bowl Oring groove as well as the old Oring and silicone sealer (!).  It was considerable work with a small hardwood "scraper," a toothbrush, and carb cleaner to get every trace of the gunk out.  But once that was done, when I fitted the new Orings into the grooves, their own "stretch" held them in place.
FWIW, I did as suggested on this site - re used all the original Honda "brass."  TBH I was a little concerned about the original float needles/seats sealing properly but once I finished the rebuild and bench synched the carbs, I installed them, turned on the fuel.  No leaks and they function as new!
