SOHC.co.uk Forums > Other Bikes
Didn't need a new project...but I got one!
Laverda Dave:
A nice looking project for those longer winter days👍.
As for the welding, I can 100% recommend a guy called Andy who runs a company called Specialist Welding.is based near Banstead. His number is: 07957 557935. He was recommended to me by SRS Engineering in Sutton, he does all their welding. I took my Triton cylinder head to him that was porous and had been subjected to really poor welding by the guy who built the engine 22 years ago. Andy did a brilliant job. I've now taken the head to Mike at SRS for blending and a surface grind.
Take the cases to Andy and he'll tell you if he can fix them. Call him first though as he does a lot of site based work.
Tell him Dave Ellis with the Dresda Triumph cylinder head sent you!
Good luck👍
SumpMagnet:
thanks Dave, I'll sound him out and see what he says
McCabe-Thiele (Ted):
I had a Triumph Twenty One, VRM 102 ETF, it was my first proper motorcycle after Mopeds & Scooters. I loved the clockwork speedometer but my Mum hated the oil leaks lol. That was part of the reason I bought my first Honda.
SumpMagnet:
I should be working on the Honda....haven;t done much to it for months....but this thing is kind of getting me hooked. If I am not careful I will be getting a flat cap, leather elbow patches and a pipe to poke at people while I tell them the shade of Polychroatic Blue on the petrol tank is all wrong for a 1947 Triumph Wombat when the total loss oil system was brought in after the Boer War.
Bike has had a total stripdown, and I am sorting out some issues with the rolling chassis before I start into the engine.
Found some of the 65 year old tinware wasn't perfect too. All sorts lurking under the paint! Nacelle top was the first thing
Holes pulled through and opened up. Welded them up and redrilled. A lot of the holes had been ovalled or slotted to make the thing fit. It's hidden under trim strips, so doesn;t show..but these had broken right through.
Fixed them all and painted it. Stuck with my Dad's choice of paint colour. Ford Cosmos Blue. Similat to the original..and ..well..it's how I remember it.
Front mudguard was next. A patch had been brazed in where the rear stay mounted. Should be a bracket rivetted to the mudguard. There was a bolt, and a horrid lashed up bracket on the inside. No. Not having that!
Ground off the braze and removed the patch. You can see what it was covering.
Chopped out the damaged area and welded a patch in. Needs cleaning up, but it's solid.
Have discovered the joy of welding 65 year old tinware. Knowing it's virtually irreplacaeble ... Did see one early front mudguard for sale. Rusty as anything...£95. One soundish one I saw went for £200. Always at the back of your mind when you blow a hole through....you aren;t going to easily find another.
So I practiced on the piece I chopped out to get the settings right, slowed it down and made tiny little stitch welds. No holes. Even in the freezing cold, I had a bit of a sweat on until it was done.
taysidedragon:
Most parts are available, either NOS or pattern parts. Buy from the decent specialists like Tricor Andy, Draganfly or Montys Motorcycles and they should be decent quality and fit. Check part numbers for your year, lots of variations that look the same but aren't!
Good info here on the range. https://triumph-tiger-90.com/
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
