Other Stuff > Desperately Seeking!!
41211-323-000 plate (rear sprocket cover)
McCabe-Thiele (Ted):
Mine is definitely chromed - by PO?
Could I be confused?
AshimotoK0:
--- Quote from: McCabe-Thiele (Ted) on September 24, 2023, 10:01:48 AM ---Mine is definitely chromed - by PO?
--- End quote ---
Probably by PO Ted .. unless later models had a chromed one.. not familiar with anything after the K1 500. Ken will know.
Oddjob:
Zinc plated originally.. I had mine chromed last time it was restored, they go really dull after a couple of years and I don't do dull.
If you aren't using that in the end Ted, let me know, I'd like to see if I can reclaim it back from the dead.
If Roos turns out to be in better shape its got your name on it Ken.
Update: Not sure now if its been chromed more likely BZB looking at my shiny new 8mm headed M6 cam cover bolts.
Still looking for the rear sprocket plate as Roos is damaged.
Mine is slightly out of shape plus the outer centre flange section is partly broken away can't remember if that is cosmetic only so could be cut off.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
