Author Topic: 41211-323-000 plate (rear sprocket cover)  (Read 1422 times)
« on: September 23, 2023, 02:32:20 PM »
The rear sprocket plate on my 500 has rusty chrome as well as being a tad out of shape in a few places.
Anyone here have one that is still undamaged - if the chrome is poor might look at powder  coating though I assume they would have to remove the chrome first - all sounds costly.
.41211 323 000 plate by Macabe Thiele, on Flickr
Re: 41211-323-000 plate (rear sprocket cover)
« Reply #1 on: September 23, 2023, 03:00:57 PM »
Think I’ve got one Ted but it’ll want coating, there’s no chrome left in it.
Did you want that widget bit I sent you a text about last night?
« Reply #2 on: September 23, 2023, 04:08:36 PM »
I've PM'd you about the widget, not too worried about the chrome on the plate  but is it dented/damaged Roo - e-mail me a photo? Thanks Ted
« Last Edit: September 23, 2023, 04:59:46 PM by McCabe-Thiele (Ted) »
« Reply #3 on: September 23, 2023, 06:30:53 PM »
I always thought these were BZP finish on K0 ..mine certainly was and just had it re zinced
« Reply #4 on: September 24, 2023, 09:29:37 AM »
This doesn't look much like chrome to me Ted ! Maybe worth stripping yours and having it zinced.
https://images.cmsnl.com/img/products/platesprkt-side_big41211323000-01_e474.jpg
« Reply #5 on: September 24, 2023, 10:01:48 AM »
Mine is definitely chromed - by PO?
Could I be confused?
« Last Edit: September 24, 2023, 10:05:23 AM by McCabe-Thiele (Ted) »
« Reply #6 on: September 24, 2023, 01:40:32 PM »
Probably by PO Ted .. unless later models had a chromed one.. not familiar with anything after the K1 500. Ken will know.
« Reply #7 on: September 24, 2023, 01:57:03 PM »
Zinc plated originally.. I had mine chromed last time it was restored, they go really dull after a couple of years and I don't do dull.
If you aren't using that in the end Ted, let me know, I'd like to see if I can reclaim it back from the dead.
« Reply #8 on: September 24, 2023, 04:11:55 PM »
If Roos turns out to be in better shape its got your name on it Ken.
Update: Not sure now if its been chromed more likely BZB looking at my shiny new 8mm headed M6 cam cover bolts.
« Last Edit: September 27, 2023, 12:20:28 PM by McCabe-Thiele (Ted) »
« Reply #9 on: October 09, 2023, 06:04:50 PM »
Still looking for the rear sprocket plate as Roos is damaged.
Mine is slightly out of shape plus the outer centre  flange section is partly broken away can't remember if that is cosmetic only so could be cut off.
Offline florence
« Reply #10 on: October 10, 2023, 10:00:57 AM »
I've got one and I think it is OK.  It's still on a wheel.  Not chrome plated.
« Last Edit: October 10, 2023, 10:18:55 AM by florence »
« Reply #11 on: October 10, 2023, 10:09:27 AM »
I'll PM you Steve.
