Author Topic: Glueing metal to metal  (Read 10526 times)
« on: September 24, 2023, 02:44:22 PM »
Quick question all, I’m needing a glue that is fuel resistant but will glue metal to metal…………epoxy resin??
Offline Skoti
Re: Glueing metal to metal
« Reply #1 on: September 24, 2023, 03:11:08 PM »
I've used JB weld on a vintage bike tank that was leaking at the fuel tap spigot and also on a carb, seems good stuff.
https://www.autoone.com.au/2110-jb-weld-tankweld-repair-kit
Skoti
1976 Honda CB750F1
« Reply #2 on: September 24, 2023, 04:55:41 PM »
Cheers Skoti, I’ll have a look
Offline Moorey
« Reply #3 on: September 24, 2023, 09:18:45 PM »
  Have a look at Belzona products as well.
Offline DomP
« Reply #4 on: September 24, 2023, 10:26:06 PM »
JB Weld is fine as long as you aren't expecting too much of it strength wise.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #5 on: September 25, 2023, 08:53:07 AM »
What are you trying to stick Roo?
Offline Matt_Harrington
« Reply #6 on: September 25, 2023, 09:49:22 AM »
Loctite do an epoxy metal glue. A mate has used it to good effect...
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #7 on: September 25, 2023, 01:51:35 PM »
Hi Roo,
Depends what kind of joint you will be glueing (behave yourselves at the back, not that kind of joint)
I have used proper Araldite (not rapid) to good effect - parts of the wings on Buccaneers were held on with it. If the joint will be subject to peel or torsion forces then you might have to rethink but tensile and shear forces are usually fine - up to a limit of course.
Nowt to do with owt but I have just returned from a 1350 mile trip on my new 350 Forza at 96.5mpg and I was never in the wrong gear  8)
Ian
« Last Edit: September 25, 2023, 01:53:06 PM by Orcade-Ian »
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #8 on: September 25, 2023, 02:36:32 PM »
Worked in the Aircraft industry 40+ years ago. Popular metal to metal adhesive was Araldite AV121. Never seen it for sale in small quantities. Grey in colour when set.
Very good glue providing surfaces are very, very clean.
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
« Reply #9 on: September 25, 2023, 03:46:31 PM »
I’ve modified the fuel tank in the 550 as I can’t get a decent lock substitute that looks alright and welded a plate to the underside of the boss on the tank to accept a bonnet pin for a push button catch. I need to glue a  heftier spring to the pin to pop the flap up enough. It just need needs to stay there so apart from compression it’s under not much stress. Can’t really think of another method to get it to stay put. I’m just revisiting fit so I can get t off for paint as I’m back to the states next month for 8 weeks.
« Reply #10 on: September 25, 2023, 03:47:50 PM »
You show have got one with decent mpg that’s astonishing!
« Reply #11 on: September 25, 2023, 04:09:46 PM »
Could you not drill a v small hole in the shaft and glue a pin in low down?  Or Am I missing the point?
« Reply #12 on: September 25, 2023, 04:14:07 PM »
It’s bonkers hard stainless Matt, I’ve a couple of new ones coming in anticipation of the inevitable
I’ll see how bullet proof they are when they get here tmrw. Good idea though hadn’t thought of that, I only know they’re made of Hardium as I re cut the thread in it as it was a USA job and was in silly measurements.
« Reply #13 on: September 25, 2023, 04:17:41 PM »
If really hard, try a carbide drill - I've got some suitable.....
« Reply #14 on: September 25, 2023, 05:17:59 PM »
I’ll let you know Matt, cheers mate.
How’s yer paw? Are you back to some hardcore pointing yet?
